Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum CS does not change Assemlby, Countryard and 3D when switching layer of component
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 364 views
tomaszciesla
tomaszciesla over 10 years ago
Another bug: When I'm changing the layer of component from Top into Bottom, the CS changes only standard layers: Top, Top Overlay, Top Paste, Top Solder into Bottom, but Assemlby, Countryard and 3D remain at the top so you have to do it manually..... for each component...... for each primitive.......
T.
  • tomaszciesla
    Temporary solution is to configure layer pairs for Countryard, 3D body and Assemlby, you have to do it for each PCB, and also for 3D body - when you switch layer for component without it the 3D model will be re orientated but content on 3D body (top/bottom) layer not
