Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Bug report - PCBLIB Inspector unable to change multi-layer pads to single layer
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 354 views
  • bug
harvie256
harvie256 over 10 years ago
This is reproducible
Steps to reproduce:
1. Add a pad to a PCB Library Component
2. Open PCBLIB Inspector
3. Select the pad (it should be a multi-layer pad by default.)  Settings should be as follows:
4. Click in the Layer row, and change to a single layer (e.g. Top Layer)
5. Expected result is the same as doing this in the pad editing dialog (changing to a single layer pad), the actual result is the pad is still a multi-layered pad but with zero set in the X-size and Y-size. See below.
