Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum using cypress CY8C5868AXI-LP035
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 497 views
I am trying to use the  CY8C5868AXI-LP035CY8C5868AXI-LP035 from the vault
it contains 2 'part numbers' if you increment the part number it shows the power block. but how do i use this?
If I label them with 2 different part id's it gives the red error banding.
If I label different numbers it places 2 parts on the pcb.
How do i use this part correctly?
Rob Berry
    e14 Contributor over 10 years ago in reply to gihu +1
    Figured it out... The unique ID has to be the same for both. -Rob
  • gihu
    gihu over 10 years ago
    You should use the same part number, for example U1. Then you should select one of them to be partA and the other one partB, so automaticly in the schematic sheet you will see the 'two' parts labeled as U1A and U1B.
    Hope that helps,
    Miguel
    -Rob
