Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Mystery of the multiple monitors and the missing layer stack manager
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 1818 views
tarribred61
tarribred61 over 8 years ago
Hey all,
I just experienced a problem with getting into the Layer Stack Manager window.  I typically use multiple monitors and frequently switch between just the laptop and one or two external monitors.  So far CS has worked well with this.  However, today I went to open the Layer Stack Manager and nothing.  The main CS window lost focus (i.e. title bar loses its color highlight) but no Layer Stack Manager window appeared.  However, I could press the ESC key and get focus back to the main window.  If I pressed the ALT-TAB key combo I could see the Layer Stack Manager running as a task.
I was able to fix this by disconnecting my laptop computer from its dock port getting back to a single screen.  Then Layer Stack Manager opened on the only screen.  After this I was able to redock to the external monitors and for now Layer Stack Manager seems to work OK again.
This looks like a bug in the software or possibly in how it gets its prior screen location from memory.
I remember that Altium Designer had similar problems back about 2009 (AD6 I think) but much worse.
Hopefully, this post helps others if they run into the same thing and maybe this can be logged as a known issue for future improvement.
  • harvie256
    harvie256 over 8 years ago
    I've seen this a few times, but it happens with several different pieces of software I use on Win10.  Essentially it ends up off screen.  Usually I can use the windows key and arrows to bring them back on the main screen.
  • e14softwareuk
    e14softwareuk over 8 years ago
    On Win 7 (and probably others) use ALT SPACE to activate the system menu of the top window and then M to move, the cursor keys will then move the window around the desktop.
