Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Export .step not exporting component bodies
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 659 views
  • step
  • 3d modelling
  • 3-d
  • circuitstudio
justinstevens
justinstevens over 9 years ago
Previously I have had good success exporting a full .step 3d model of my completed PCB project, which I then 3d print to check for fit and clearance in the enclosure.  But now, with the latest CircuitStudio release, it no longer seems to be able to export component bodies.  The top pane of the STEP export window is missing "Components with 3d bodies".  Viewing my board in 3d mode of course shows everything correctly with 3d bodies on every component.  Did this feature get removed for some reason?
  • justinstevens
    Interesting... Problem solved.  I was converting the step model to STL using the converter at makexyz.com and it was not including the component bodies for some reason!  I tried a different converter at 3dtransform.com and it worked perfectly with all component bodies.
