Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Multilayer does not appear on Composite Drawing
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 1063 views
tomaszciesla
tomaszciesla over 9 years ago
Hi all,
I've found another bug: Multilayer does not appear on Composite Drawing
Outputs -> Print -> Print Preview -> right click -> configuration -> leave only Multilayer
  • e14softwareuk
    e14softwareuk over 9 years ago
    Hi Thomasz, just tested by drawing somes lines on the layer "Multi-Layer" and they came out on the print just fine. What have you drawn on that layer that isn't displaying?
  • tomaszciesla
    tomaszciesla over 9 years ago in reply to e14softwareuk
    Hi Peter,
    Pads and vias are not present.
    T.
  • e14softwareuk
    e14softwareuk over 9 years ago in reply to tomaszciesla
    You will need to turn on the copper layer (for example) to see a pad. What type of output are you trying to generate, just a print of pads and vias? If so just through hole ones?
  • tomaszciesla
    I want to generate the output with pads of the connectors (they are only through hole pads on the PCB), I've already done manual mechanical layer with holes.
    It's a counter intuitive - when I go to single layer mode on the PCB on Multilayer all through hole pads are highlighted, so if single layer mode sees them that way why printing can't?
  • e14softwareuk
    Thanks for explaining, it now makes sense what you are trying to achieve. I can also see that from an output printing perspective what size pads would multi-layer print because each layer on your connector could be a different size. How would it know to print top copper, solder mask etc. At present I cannot think of a way to generate the output you desire.
