Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Can't change Paste and Solder Mask Expansion using Inspector
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 714 views
tomaszciesla
tomaszciesla over 9 years ago
While making a component in library I can tick only Paste / Solder Mask Override using PCB Inspector. Then the value of Expansion can't be typed using Inspector - I had to do it manually for each pad...
  • e14softwareuk
    e14softwareuk over 9 years ago
    Hi Thomasz, that's correct unfortunately, you have the use the property dialog to change the numeric value. Depending on what you are trying to achieve there are other methods such as using a design rule on the PCB to adjust based on component or pad class.
  • tomaszciesla
    tomaszciesla over 9 years ago in reply to e14softwareuk
    ok thx Peter
