Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum PCB Custom Library connectors getting flipped 180 Deg.
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 819 views
opeongo73
opeongo73 over 9 years ago
I am fixing up my custom connector library and have the connector(s) labeled from left to right as Pin 1 to Pin x.  For some reason while saving the library, CS deems it necessary to flip the connectors 180 degrees so that Pin 1 is now on the right. I can find no way to correct this or stop this from happening. Is this a bug or am I doing something wrong? This now makes the connectors on the pcb layout reversed from what they should be.
  • e14softwareuk
    e14softwareuk over 9 years ago
    Hi Jim, did you copy or derive from a copy of a vault component your library part?
  • opeongo73
    opeongo73 over 9 years ago in reply to e14softwareuk
    Hello Peter: No my pcb libraries are copied over from 99SE.
  • e14softwareuk
    e14softwareuk over 9 years ago in reply to opeongo73
    Do you have a small sample project you could send including your connector library? If you email me directly I will take a look as it could be something.
  • opeongo73
    Peter:Another problem that I encountered within the custom library is that when I try to rotate a component using Cntl-A; M; and then space bar to rotate the component it rotates the component 180 degrees and not 90 degrees as stated in the hot keys.
    Jim
  • e14softwareuk
    Hi Jim, the rotation step is configurable, see File > System Preferences > PCB Editor > General, Other : Rotation Step field.
