Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum SVN error
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 1453 views
SVN error
fuubar67
fuubar67 over 9 years ago
I am using 2 svn repositories, one with Assembla.
I amble to check out projects, but the files indicated that they are being refreshed and any time you click on 1 it throws a Version control error " Notifications are allowed on main thread only".
I am on CS 1.4.1 build 99.
Any Ideas, besides deleting the svn directory.
  • compeoree
    compeoree over 6 years ago in reply to jonasss +1
    I seemed to have fixed mine by unchecking the "Write debug information into the Output Panel" option in "System Preferences" -> "Data Management" -> "Version Control"
  • e14softwareuk
    e14softwareuk over 9 years ago
    Not used remote repositories only file based ones but never seen this error. Could the folder structure be corrupt, you could install TortoiseSVN and see what it makes of the local folder and remote repository.
  • gbingersoll
    gbingersoll over 7 years ago
    I'm wondering if anyone ever found a solution to this. I am seeing the same error in 1.5.1 build 13 running on Windows 10. I can view my repository through Tortoise SVN (I even tried VisualSVN with the same result), so the repositories are not corrupt. But if I enable SVN in the CircuitStudio system preferences, I get this error popping up every time I click on a file. Same result whether I use the internal SVN or external svn.exe.
  • e14softwareuk
    e14softwareuk over 7 years ago in reply to gbingersoll
    Might be worth testing if switching between internal and external SVN make a difference, see File > System Preferences then Data Management > Version Control.
  • alprisa
    alprisa over 7 years ago in reply to gbingersoll
    I am having the same problem. Is there any solution?
  • jonasss
    jonasss over 6 years ago
    And I'm ungladly joining the line of people with this error message.
    Another thing that's happening right here, is that the internal CS SVN throws only error messages when I try to checkout a project. Tortoise SVN at least is able to check out correctly. But then the above mentioned error message keeps appearing "Notifications are allowed on main thread only".
    Did somebody manage to get this running?
  • compeoree
