Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Forced polygon repour or make unpoured
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 2733 views
dpd
dpd over 9 years ago
Hello, when editing anything in an existing PCB document with polygon pours, the automatic repour dialog appears ad forces me to make an edit to the polygon (either make unpoured or repour). I'm only changing the nets on some connections and I don't want any copper to be modified during the process.
In Altium Designer it is possible to not take any action and leave the polygon as is (even if this can cause DRC errors). Is this somehow possibile in CircuitStudio?
  • yadhu22krish@gmail.com
    yadhu22krish@gmail.com over 9 years ago
    No.Either you need to unpour or repour the polygon.
  • ohyva
    ohyva over 9 years ago
    I typically unpour all polygons when starting any PCB editing, and repour those all after all edits are done.
    This way those are not disturbing or interrupting my work and I van "see through" any pour in multilayer PCB.
    When repouring and having overlapping pours you have to make sure those are poured in right order.
