Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Reassociate PCBDoc with Schematic
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 1362 views
tbmph
tbmph over 9 years ago
Hi
we had an issue on our system. In two projects the prj files was destroyed.
I imported the SchDoc and the PCBDoc to a new project, but now all associations between schematics and pcb are lost.
Any chance I can reassociate both files again?
  • jimku
    jimku over 9 years ago
    One way to do this is to create a new project with Create Project Folder checked. CircuitStudio will create the folder containing the file project_name.PrjPcb in that folder. Copy (using Windows Explorer) all of the sch_file.SchDoc and pcb_file.CSPcbDoc files to that same folder. Then right click on project_name.PrjPcb in the Projects pane in CircuitStudio and select “Add Existing to Project” and navigate to the new project folder and select the schematic and PCB files that you copied to that folder. Repeat this last step for all of the files. Then right click on project_name.PrjPcb in the Projects pane in CircuitStudio and select “Compile PCB Project project_name.PrjPcb”. Now all should be re-associated.
