Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Problem with integrated SVN function
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 674 views
tueftler@work
tueftler@work over 9 years ago
Hi there.
I would like to use the integrated SVN function.
The project is added to the SVN with success.
If i make a right mouse click to the "project\version control\commit whole project", there comes the check in window.
All parts of the project are included.
Now i fill in some text and click ok.
-> A dialog box shows with the following note:
"svn.exe: invalid option character: 3       Type 'svn help' for usage"
If i checkin spare files, it worked properly.
There is one schematic file which generates these error.
If i remove that file on "commit whole project" the checkin is running properly, too.
File name of the file: "-30V_StepUp.SchDoc"
Is there a bug included in svn support?
Greetings, Bjoern
  • e14softwareuk
    e14softwareuk over 9 years ago
    Hi Bjoern, it's the leading "-" negative sign in the file name that is causing the issue, if you rename to perhaps "neg30V_SteupUp.SchDoc" it should work. I will make Altium technical people aware of this issue.
  • tueftler@work
    tueftler@work over 9 years ago in reply to e14softwareuk
    Hi Peter,
    i can confirm that.
    Without the "-", SVN works good.
    Hope they will fix that in the next versions...
