Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum CircuitStudio Support - 'How-To' Videos
  • Locked Locked
  • Replies 8 replies
  • Subscribers 91 subscribers
  • Views 2753 views
  • video
  • How To
  • circuitstudio
alexsander_altium
alexsander_altium over 9 years ago
Hello All,
We've released some CircuitStudio How-To videos, here's what we have so far:
#VideoDescription
1How to download and activate your CircuitStudio licenseHow to download and install CircuitStudio then signing in with your email / password and checking you have your license.
2How to create polygon pours and internal planesQuickly pour a polygon, define layer and net and learn how design rules influence the polygon connection style (thermal reliefs etc). Internal planes are edited as negative layers, adding lines and other shapes leaves gaps in the copper allowing the creation of split planes.
3How to Create a ComponentCovers schematic symbols, PCB footprints and attaching 3D models. Learn how to make fully purchasable parts by using supplier links. Advanced topics such as multi-part components are not covered.
4How to Start a New ProjectLearn how CircuitStudio organises files into projects and how templates can be used when creating a new project. Recommendations include establishing design rules before launching into the design itself. Demonstrates how rules checking can highlight errors on the schematic.
5How To Keep Organized with Multi-sheet DesignsCovers flat and hierarchical multi-sheet designs and the use of ports to connect up between sheets. More advanced topics such as repeated blocks are not covered.
6How to Utilize Cross-Probe, Masking and HighlightingCross probe between schematic and PCB with either continuous or jump mode. Also covers filter mode to browse through a list of PCB objects. The demonstration shows a split document window to view the schematic and PCB simultaneously, for those with multiple monitors you can also tear off a document and move to a second monitor.
7How to Compare DifferencesHow has a design changed? Find out using the comparator tool.
8How to RouteInteractive routing demonstration including push & shove and ability to route differential pairs. Loop removal is covered, an easy way to adjust existing routing without having to first rip it up. The integrated auto-router is briefly mentioned.
9How to Create and Edit Your Board ShapeDemonstration of editing tools and the best practice of also defining the outline shape on the Keep Out and Outline layers to help when generating manufacturing data.
10How to Setup and Route A Differential PairCovers setting up differential pair definitions on the schematic, passing through to the PCB and establishing design rules that influence how the traces will route.
11How to Navigate The User InterfaceCovers the ribbon menu, panels, shortcuts. Not covered in this short introduction are full coverage of dockable / floating panels and multi-monitor operation.
12How to Create Keepout ObjectsHow to draw keepout objects and the different betwee global and layer specific. Layer specific keepout objects are not included in manufacturing data such as Gerber and ODB++.
13How to setup design rulesLearn about rule categories, creating new rules and setting priorities.
14How to Generate ClassesClasses allow the logical grouping of objects which helps when defining targeted design rules.
15How to Setup and Route Differential PairsThis video will cover how to create, setup rules, and route differential pairs
16How To Find and Place ComponentsThis video will cover some basics on how to find and place components in your design
17How to use version controlThis video will cover how to setup and use the built in version control in CircuitStudio
18How to Reuse Output Documentation SettingsThis video will cover how to reuse your output documentation settings, such as gerbers, drill drawings and so on.
19How to Configure Your BOMThis video covers how one can configure their BOM document to their specific needs
20How to DimensionThis video goes over the different dimensioning types and how to access them
21How to create Schematic & PCB PrintoutsThis video covers how to create schematic and PCB printouts
22How to Use the Selection FilterFind out how to use the selection filter in CircuitStudio
23
How to manage Layer Sets
Discover how to create, edit, and remove layer sets in CircuitStudio
24How to Create a 3D PDFDiscover how to create a 3D PDF of your PCB to send to your colleges, or employer
We will continue to add videos as they're done, so stay tuned!
Alexsander Tamari, Altium
  • slowertech
    slowertech over 8 years ago in reply to alexsander_altium +1
    I think maybe there is some confusion on what I said. I use this all the time and anyone else can also do this. Just enable cross select mode in both schematic and layout, select the components in the…
  • slowertech
    slowertech over 8 years ago +1
    How to import a logo onto the layout?
  • alexsander_altium
    alexsander_altium over 8 years ago in reply to slowertech +1
    slowertech, I'm sorry. You're correct! I'll be sure to put that in the cross-probing video. Thanks!
  • slowertech
    Maybe a video on using cross select mode, selecting all the components in a specific circuit and then using reposition components to place them in the selected order on the layout?
  • alexsander_altium
    Thanks for the input slowertech, we do have a cross probing video on the way. Unfortunately CircuitStudio, unlike Altium Designer does not the capability to automatically populate your cursor in the PCB with symbols you've selected in the schematic.
  • slowertech
    I think maybe there is some confusion on what I said. I use this all the time and anyone else can also do this. Just enable cross select mode in both schematic and layout, select the components in the schematic in the order you want them re-positioned in layout, then just type in reposition selected components in the search window and layout and have at it.
  • slowertech
  • alexsander_altium
  • alexsander_altium
    thats a good idea, thanks!
  • tarribred61
    tarribred61 over 8 years ago
    There seem to be a lot of posting in the forum about lack of component libraries.  Maybe there could be a How-To/Blog entry discussing options on where to get schematic and PCB libraries including the vault, manufacturer's web sites (using Altium library compatibility), Altium design content live, and free and paid services (ultralibrarian, snapeda, etc).
  • jstrautman
    jstrautman over 8 years ago in reply to tarribred61
    I also would like a video about navigating/using the vault library.  My guess is that there will not be a video so long as the interface and navigating the vault is so broken because it would just expose it further.
