Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Could it possible to change shurtcuts ?
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 2595 views
  • shortcuts
  • shortcut
datalight
datalight over 8 years ago
Hi All
I recently used almost 10 years Altium Designer. My new company has CircuitStudio and shortcuts are really different from Altium. I didn't found but I want to ask could it possible to change shortcuts in CircuitStudio ?
Best Regards
  • e14softwareuk
    e14softwareuk over 8 years ago in reply to e14softwareuk +1
    Although there is no official way to change the shortcuts it is possible by editing AdvSch.rcs and AdvPcb.rcs in the program files folder with a text editor if you are comfortable doing this. Remember…
  • e14softwareuk
    The shortcut keys in CircuitStudio are fixed and cannot be edited or reassigned.
  • e14softwareuk
    Although there is no official way to change the shortcuts it is possible by editing AdvSch.rcs and AdvPcb.rcs in the program files folder with a text editor if you are comfortable doing this. Remember to keep backups and editing is at your own risk.
  • muessigb
    muessigb over 6 years ago
    The keys are really annoying when typing on a non-English keyboard, like a German one, as shortcuts like * for changing layers is impossible to use.
  • tarribred61
    tarribred61 over 6 years ago in reply to muessigb
    A workaround for you might be to use the Shift+F1 key combo to bring up the context specific shortcuts/commands and choose from there.
    Does a German mapped keyboard not have the numeric keypad?  The * used for shortcut to switch layers is the multiply (*) on the numeric keypad and not the asterisk on the shift-8 part of the keyboard.  If you have a laptop without a numeric keypad then I know you can get usb attached numeric key pads or use a usb keyboard.
    Sadly, there I have found no easy way to remap the shortcuts but there are probably utility programs that can do it or could implement multiple key macros.  Supposedly there is a way to edit the Windows registry keys or follow the AdvSch.rcs and AdvPcb.rcs instructions.  On my system these rcs files are here: C:\Program Files (x86)\Altium\CS\System.  If you open AdvPcb.rcs with a text editor you can search for the word Multiply.  Then you will find on about line 700 the shortcuts for Next Signal Layer and Previous Signal Layer.  You might be able to experiment with changing the shortcuts.  I had no luck doing this. Some of this is documented here: https://www.altium.com/documentation/altium-dxp-developer/server-configuration-files
    I'd make a backup of the file before changing it though.
