Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Is it possible to design a simple single layer flex PCB in Circuit studio?
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 1239 views
  • flex pcb
jtoul
jtoul over 8 years ago
I'd like to design a simple single layer FlexPCB - more like a glorified cable with FPC connector on one end, and copper pads positioned along the cable. There are no components, just a few traces and copper pads. I was hoping to do this using Circuit Studio but I notice the layer stack is very limited and it appears impossible to edit to a single layer stack.
Is there any way to create a simple flex PCB and specify the layer stack in Circuit Studio?
  • e14softwareuk
    e14softwareuk over 8 years ago
    Hi Jean. If you are undertaking a very simple design of just a flex board then this could be done in CircuitStudio. You are basically describing just a single sided PCB but made with different materials. You would provide Gerbers to the manufacturer along with fabrication instructions so the actual layer stack showing in CS is not necessarily what you have to have built - you can take what layers you need to achieve your end design.
    Anyone from the community already done this and willing to share your experience?
