Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Change Scaling of CircuitStudio
  • Locked Locked
  • Subscribers 91 subscribers
  • Views 1186 views
adamwebber
adamwebber over 8 years ago
I've found that going from a 1080 monitor to a 4K monitor has really put a damper on my ability to see the screen while using CS.  In case other people are having a difficult time, I found a fix a while ago and I thought that I should share.
1-Find the main executable (DXP.exe)
     a-Go to your search bar
     b-Type CircuitStudio
     c-Right-Click and select 'Open File Location'
     d-Right-Click the shortcut and select 'Properties'
     e-Click the button 'Open File Location'
2-Right-Click DXP.exe
3-Select 'Properties'
4-Click on the 'Compatibility' Tab
5-Check the box next to 'Override high DPI scaling behavior Scaling performed by"
6-In the drop-down, select 'System'
7-Press 'OK'
Now your CircuitStudio program will take on the scaling of whatever you have set up on your display settings.
Happy Birthday!
  • kaipyroami
    kaipyroami over 8 years ago
    Excellent!
    Thank you!
  • e14softwareuk
    e14softwareuk over 8 years ago
    Thanks for sharing, great tip and will hopefully be very helpful to the community now 4K monitors are becoming more common.
  • vergil
    vergil over 7 years ago
    Hm. Library is not fully shown:
    I can't scroll it down, it is a final position, but there are more components here!
    Update. I changed the scalling in the windows options to 100% (it was 225%), and moved all menus (symbols, footprints) up. After it I set scalling factor back to 225%, and now it works better:
    But the fonst and all appliction in general looks not legibly. If I set the scalling factor to 100%, it is legibly, but not too small. image
  • dweaver309
    dweaver309 over 6 years ago
    Great tip works!
