Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Can't place symbol template in schematic library editor
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 1017 views
  • schematic library
  • template
  • circuitstudio
  • symbol
jaza_tom
jaza_tom over 8 years ago
Like the title says.
See video:
https://youtu.be/IMV87PkK1vk
How does one go about using the template schematic symbols in that dropdown?
  • e14softwareuk
    e14softwareuk over 8 years ago +1
    Not sure what's going on, as soon as you click the template it should be placed at the origin. Try hitting Ctrl-PgDn to zoom everything into view and see if the symbol is appearing elsewhere and perhaps…
  • tarribred61
    tarribred61 over 6 years ago in reply to johnmosborneuk +1
    For what it is worth, it does seem to be working as expected for me when I tested today.
  • e14softwareuk
    Not sure what's going on, as soon as you click the template it should be placed at the origin. Try hitting Ctrl-PgDn to zoom everything into view and see if the symbol is appearing elsewhere and perhaps try creating a new component and adding a template as the first thing.
  • jaza_tom
    jaza_tom over 8 years ago in reply to e14softwareuk
    Not sure what was happening either.  Appears to be working as you describe today.
  • johnmosborneuk
    johnmosborneuk over 6 years ago in reply to e14softwareuk
    I'm having exactly the same issue, I select a symbol template and nothing happens?  I've tried Ctrl-PgDn and restarting the PC but still nothing happens when I pick a templace.
    FYI I'm on CS version 1.5.2 (Build 30) on Windows 10 Pro version 1909.
  • tarribred61
