Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Part Swapping
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 663 views
Part Swapping
fuubar67
fuubar67 over 8 years ago
I have a group of resistor packs. I need to break out from FPGA and then order the connection to multiple resistor packs. Can you set up the library parts that a part swap can be done between different ref des parts of the same value? I have set up the rpacks as multipart device.
  • e14softwareuk
    e14softwareuk over 8 years ago
    You can swap pins/parts within one physical device but there is no direct support for swapping between different physical devices. Maybe you could make the FPGA pins swappable (where appropriate) to help with the routing.
  • fuubar67
    fuubar67 over 8 years ago in reply to e14softwareuk
    In my case I have, multiple FPGA devices of same kind, and want to keep pinout frozen.
  • e14softwareuk
    e14softwareuk over 8 years ago in reply to fuubar67
    Given you cannot pin swap between different physical devices would it be possible to use individual resistors rather than packs? Another though if you resistor packs are placed next to each other perhaps create a 'fake' resistor pack component that has all the resistors incorporated so that you can then swap around at will.
