Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Is it possible to move an entire PCB design in the workspace?
  • Locked Locked
  • Subscribers 92 subscribers
  • Views 6411 views
  • pcb origin
lamabrew
lamabrew over 8 years ago
In one of my early/still learning CS designs I managed to position the board shape at the absolute origin (0,0) instead of centered in the workspace. (and before I realized why this was bad)
I now need to put things to the left/below (0,0). Is there a way to move the relative origin of everything in the design? I say 'everything' because I locked some components to avoid selecting them, as well as there are quite a few guide lines, outlines and other odds and ends that didn't move when using a "Select All" followed by a "Move selection X,Y" sequence.
I can fix all of that up by hand but I was hoping there was some better way to fix my mistake.
  • jimku
    jimku over 8 years ago
    Have you tried to un-protect locked objects before using a "Select All" followed by a "Move selection X,Y" sequence?
    Go to System - Preferences - PCB Editor - General, then under Editing Options, remove the check mark on "Protect Locked Objects" then "Select All" followed by a "Move selection X,Y". When finished moving go back and then select the check box to "Protect Locked Objects".
  • lamabrew
    lamabrew over 8 years ago in reply to jimku
    Hi Jim,
    thanks - that was much better than hunting down all the locked objects one by one. I did have to edit the guides one by one but as I shifted by 100,100 that was easy math.
  • d.rein
    d.rein over 8 years ago in reply to lamabrew
    This seems to move the layer content, but not the board outline itself. What am I doing wrong?
  • e14softwareuk
    e14softwareuk over 8 years ago in reply to d.rein
    You should be able to move the board shape using Home | Board Shape > Move Board Shape.
  • mars01
    mars01 over 8 years ago in reply to d.rein
    To move Board Shape:
    Ribbon Menu -> Home -> Board Shape -> Move Board Shape
  • d.rein
    d.rein over 8 years ago in reply to e14softwareuk
    Ok, understood. You have to set a large grid (e.g. 50 mm) and then move board and layer content in two steps to keep them aligned. Then you have to move the board orgin in a third step (if you want to keep component coordinates). Not intuitive, but it works.
