Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum "Update PCB With Current Footprint" Not Updating Footprint
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 1715 views
bugrobotics
bugrobotics over 8 years ago
I have the CSPcbDoc file open that I'd like updated with the new footprint.    The change I made was adding a dot on the top overlay to indicate pin 1 of the component.  Nothing is updated.  Any ideas?
  • adamwebber
    adamwebber over 8 years ago +1
    I've had this problem before. It's when I think I'm using one library but it turns out that I'm using a different one. Check your links and make sure that you are updating the correct library.
  • adamwebber
  • bugrobotics
    bugrobotics over 8 years ago in reply to adamwebber
    Thanks for the reply James.  I most certainly was using a similarly named object in the same library.  Thanks again.
