Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Own Vault for Companies
  • Locked Locked
  • Replies 7 replies
  • Subscribers 91 subscribers
  • Views 1508 views
  • circuit studio
  • vault
loxeras
loxeras over 8 years ago
Hello
We use Altium Circuit Studios in our company. Now we need a "Private Vault" or a shared library, that everyone can use and edit all the components we have. Now everyone has his own library but this resulted in a huge mess.
Is it Possible to build a own Vault or something like this?
Greetings
  • e14softwareuk
    e14softwareuk over 8 years ago +1
    Hi Dario. CircuitStudio does not support private vaults only the online one. If you have a shared network drive then you should be able to have all engineers sharing centralised integrated libraries (…
  • mars01
    mars01 over 8 years ago +1
    If you use SVN (subversion) you could make available the library's for your co-workers. We use Tortoise SVN and this open-source software allow the user to lock the file that is edited (so another user…
  • loxeras
    loxeras over 8 years ago in reply to e14softwareuk +1
    Hi Peter Thanks for the answer. I will look if i can find a working Librarian tool. Are there shared Vaults for the Normal Altium?
  • e14softwareuk
    Hi Dario. CircuitStudio does not support private vaults only the online one. If you have a shared network drive then you should be able to have all engineers sharing centralised integrated libraries (*.intlib). Updating the libraries would probably be better handled by a librarian or at least in a controlled manner. The source files for the integrated library could be shared and allow one user at once to update and publish the results. You would also need a procedure in place so that once a component is created or updated the other engineers are made aware and can update their designs where appropriate.
  • mars01
    If you use SVN (subversion) you could make available the library's for your co-workers. We use Tortoise SVN and this open-source software allow the user to lock the file that is edited (so another user can't edit while current edit is in progress). CS has embedded support for SVN so everybody will see in the Project Tab if the files are out-of-date.
  • loxeras
    Hi Peter
  • loxeras
    loxeras over 8 years ago in reply to mars01
    Thanks for the answer. I looked ad it. Is it the Option "SVN Database Library" in Circuit Studios?
  • e14softwareuk
    e14softwareuk over 8 years ago in reply to loxeras
    Altium Designer has full support for vaults but CircuitStudio does not - the only one it can access is the online Altium provided vault. Both Altium Designer and CircuitStudio can access library files (intlib, schlib, pcblib) so if you are needing to share between the two packages then library files will be the way to go.
  • e14softwareuk
    I don't believe CS supports these.
  • laur_cleveron
    laur_cleveron over 7 years ago in reply to e14softwareuk
    As a slightly-middle-finger-ish gesture, right-clicking a .LibPkg project shows SVN Database Library Maker wizard. This is a tool that enables one to create an SVN-backed Database Library. I assume it works well, as indeed, it seems CS can't use it...
