Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Out of date STEP file export
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 709 views
edsinger
edsinger over 8 years ago
Hi, I'm trying to export a 3D STEP model of my PCB. For some reason it consistently exports  a very out-of-date and stale version of the PCB (I've since updated my board outline, etc and these changes aren't reflected).
Am I missing something in terms of compile / re-compile of the design? I've tried everything.
Also, the the board looks correct in the CS 3D view.
Thanks!
  • e14softwareuk
    e14softwareuk over 8 years ago
    One thing to check is if you are looking at the correct generated STEP file. Have you deleted this and make sure that when you run STEP export it is recreated? It could be the export is failing and the old file is left behind.
  • edsinger
    edsinger over 8 years ago in reply to e14softwareuk
    Thanks for the reply. The issue is fixed but not 'solved'...after a series of open/close/restart/deletes it finally updated to the new design. Not sure what did it but probably a bug others will hit as well...
