Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Nets Become Disconnected When Aligning Components
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 642 views
bugrobotics
bugrobotics over 8 years ago
I may be doing something wrong but this has always been an issue.  I'll assign nets to a component and if I move the components by clicking on a single component and move then any attached nets move.  If I use the align tool then nets get left behind.  Any way to get around this issue?
  • e14softwareuk
    e14softwareuk over 8 years ago
    You can select how things work when moving components with the mouse but I believe the align commands do disconnect pins.
  • bugrobotics
    bugrobotics over 8 years ago in reply to e14softwareuk
    Thanks for the reply.  Is this something on the developer's radar to fix?
  • e14softwareuk
    e14softwareuk over 8 years ago in reply to bugrobotics
    Altium have not yet released the roadmap that was mentioned some time ago so we do not know what to expect. However this could be a feature that would actually be more trouble than it's worth - I'm thinking of all the cases where it will mess up otherwise good and near wiring. Agreed if they could provide an option to disconnect or drag (like they do for manual movement) then it would be a good idea. Altium do monitor these forums so... Altium will you please add this as a feature request.
