Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Shelving Polygons
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 3331 views
Shelving Polygons
jimolson
jimolson over 7 years ago
Occasionally in a PCB layout the copper polygons clutter your view of the board so severely that it is necessary to briefly suppress (or "shelve", in Altium parlance) these polygons.
After you are finished tinkering with traces under/over the offending polygons, they returned to normal view.
How do you shelve polygons in CS?
Jim Olson
Indianapolis, IN US
  • voltsandjolts
    voltsandjolts over 7 years ago
    Three methods available:
    (1) Double click on polygon then un-check "is poured"
    (2) Type "unp" into the search box at the top right of the main CS window, then select the "set all to unpoured" option.
    (3) Select a polygon, right-click,  select "Polygon Actions" > Set all/selected to (un)poured..etc
