Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Altium: Repeating SPI/I2C Blocks
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 1153 views
  • altium designer18
  • i2c bus
  • bus
  • pcb
  • spi
  • design:
mohsin445
mohsin445 over 7 years ago
What is the proper way of repeating I2C/SPI blocks?
Since we know in the case of SPI blocks, MISO, MOSI & SCK must all be tied together in a single bus for communication to happen.
I have read the similar https://electronics.stackexchange.com/questions/280014/altium-repeated-blocks-with-shared-ports on the forums regarding this issue but didn't found the answer satisfactory. The person who asked the question only had to place the block 3 times, so putting them directly on schematic made sense.
But in my project, I need 6-7 similar blocks for I2C and SPI. I don't know exactly at this point so using Repeat will be very beneficial for me in the long run.
Here is my top sheet:
I have successfully made Chip Enable into bus since they are all unique. But I need to tie the MISO/MOSI/SCK together for all repetitions.
Also I am getting this error currently:
A generic answer on how to connect multiple SPI/I2C blocks together would be really appreciated. Or a definitive one that this is not possible.
Thank you for your help.
  • e14softwareuk
    e14softwareuk over 7 years ago
    The error message is probably because something has duplicate unique IDs. Check the properties for AIN1 and AIN0 and if you find a duplicate then reset one of the unique IDs.
