Altium CircuitStudio
  • Altium CircuitStudio
Documents Getting Started with CircuitStudio: (#11) Generating Manufacturing Data
  • Author Author: e14softwareuk
  • Date Created: 6 Jun 2017 12:51 PM Date Created
  • Last Updated Last Updated: 6 Oct 2021 9:19 PM
  • Views 1741 views
Now that the design and layout of the PCB is complete it is time to produce the output documentation needed to get the board reviewed, fabricated and assembled. Because a variety of technologies and methods exist in PCB manufacture, CircuitStudio has the ability to produce numerous output types for different purposes.
Assembly Outputs:
  • Assembly Drawings - component positions and orientations for each side of the board.
  • Pick and Place Files - used by robotic component placement machinery to place components onto the board.
Documentation Outputs:
  • Composite Drawings - the finished board assembly, including components and tracks.
  • PCB 3D Prints - views of the board from a three-dimensional view perspective.
  • Schematic Prints - schematic drawings used in the design.
Fabrication Outputs:
  1. Final Artwork Prints - combines various fabrication outputs together as a single printable output.
  2. Gerber Files - creates manufacturing information in Gerber format.
  3. NC Drill Files - creates manufacturing information for use by numerically controlled drilling machines.
  4. ODB++ - creates manufacturing information in ODB++ database format.
  5. Power-Plane Prints - creates internal and split plane drawings.
  6. Solder/Paste Mask Prints - creates solder mask and paste mask drawings.
  7. IPC-2581 Standard - creates an XML-based single file format that incorporates a rich range of board fabrication data – from layer stackup details though to full pad/routing /component information and the Bill Of Materials (BOM).
Report Outputs:
  1. Bill of Materials - creates a list of parts and quantities (BOM), in various formats, required to manufacture the board.
Table of Contents
image11-GeneratingGerberandBillofMaterials.pdf
