Altium CircuitStudio
  • Altium CircuitStudio
Documents Am I able to purchase an old version of CircuitStudio?
  • Author Author: jamesharrimanaltium
  • Date Created: 8 Jan 2018 10:15 AM Date Created
  • Last Updated Last Updated: 6 Oct 2021 9:28 PM
  • Views 1172 views
When you purchase the latest version of CircuitStudio you may use the new license on an older version of the software. The license activation downloads the appropriate *.ALF file for the version of CircuitStudio being activated.
Old versions may be downloaded here (requires your CircuitStudio login):
http://altium-install.s3.amazonaws.com/CircuitStudio/CircuitStudioSetup.exe is version 1.2
http://altium-install.s3.amazonaws.com/CircuitStudio/CircuitStudioSetup1.3.exe is version 1.3
https://altium-install.s3.amazonaws.com/CircuitStudio/CircuitStudioSetup1.4.exe is version 1.4.0
https://altium-install.s3.amazonaws.com/CircuitStudio/CircuitStudioSetup1.4.1.exe is version 1.4.1
https://altium-release-manager.s3.amazonaws.com/CircuitStudio_1/CircuitStudioSetup_1_5_1.exe is version 1.5.1
https://altium-release-manager.s3.amazonaws.com/CircuitStudio_1/CircuitStudioSetup_1_5_2.exe is version 1.5.2
Evaluation Version (same software, different installer doesn't require sign in to run installer):
https://altium-release-manager.s3.amazonaws.com/CircuitStudio_1/CircuitStudioSetup_1_5_2_eval.exe is version 1.5.2 Evaluation Installer.
Offline version - special request only:
A special offline installer is available by request, that is designed for offline sites and once installed, the checking for future updates is not functional (and can appear to work so is misleading if this functionality is not fully understood). If you require this special installer, please contact support on software (at) element14 dot com.
  • faq
  • licensing
  • circuitstudio
  • installation
  • jamesharrimanaltium
    jamesharrimanaltium over 7 years ago in reply to tarribred61
    Hi Thomas,
    I've updated the post above. Please request the offline installer that can be used for your archive, but keep in mind that in the CircuitStudio software that's installed, the updater doesn't function, even though it looks like it's able to check for updates (because this installer is only intended for no-Internet-access sites).
    Best regards,
    James Harriman
    Altium
  • tarribred61
    tarribred61 over 7 years ago
    Hi,
    Are there updates to this page for versions newer than 1.4.1?
    Is there anyway to download the full installation package instead of just the installers?  I'd like to archive version 1.5.2 for future use.
    Thanks in advance.
