Altium CircuitStudio
  • Altium CircuitStudio
Documents How do I get help on commands, dialogs, panels, etc…?
  • Author Author: jamesharrimanaltium
  • Date Created: 8 Jan 2018 10:51 AM Date Created
  • Last Updated Last Updated: 6 Oct 2021 9:28 PM
  • Views 592 views
Use the following methods to locate information on a particular resource:
Within the software, hover over a Ribbon button, menu command, dialog, panel, or design object, and press F1.
A related help topic is displayed, and you may search for your questions in the CircuitStudio documentation.
While using an interactive command such as routing a track on your PCB, press the ~ tilde key, which is typically located above the Tab key on your keyboard. The context sensitive menu will display the shortcuts that are active during that command. After memorizing the shortcut, press Esc to return to the command, then use the shortcut. To exit the command itself, press Esc again.
  • documentation
  • shortcuts
  • accelerator keys
  • faq
  • circuitstudio
