Altium CircuitStudio
  • Altium CircuitStudio
Documents Error when launching IPC-2581 exporter
  • Author Author: e14softwareuk
  • Date Created: 16 Jan 2018 8:47 AM Date Created
  • Last Updated Last Updated: 6 Oct 2021 9:28 PM
  • Views 1725 views
Applies to Version: [1.4.1]
Error Report
There is a known issue where the IPC-2581 exporter fails with an error message similar to:
Error while initializing IPC-2581 Support CLR Host: Unable to create .Net object Altium.OutputJobFactory from assembly C:\ProgramData\Altium\CircuitStudio\{guid}\Extenions\\IPC2581_CS Dev\Altium.Ipc2581.dll
{guid} will be a long number and unique to that particular installation.
How to Fix
This is a simple error to fix, just follow the steps below.
  1. Shut down CircuitStudio
  2. Go to the folder mentioned in the error message, the path up to the Extensions folder:
    C:\ProgramData\Altium\CircuitStudio {guid}\Extensions
  3. Within the Extensions folder is a folder named IPC2581_CS.
    Rename this to IPC2581_CS Dev (note the space before Dev)
  4. Within the Extensions folder there is a file named ExtensionsRegistry.xml
  5. Open this file in a plain text editor such as Notepad.
  6. Near the bottom of the file there is an entry:
    <Path>C:\ProgramData\Altium\CircuitStudio {guid}\Extensions\IPC2581_CS</Path>
  7. Please add the " Dev" part that is missing:
    <Path>C:\ProgramData\Altium\CircuitStudio {guid}\Extensions\IPC2581_CS Dev</Path>
  8. Save the file and launch CircuitStudio
Everything should now work as expected.
  • platform
  • circuitstudio
  • diondamato
    diondamato over 8 years ago
    I have this problem, but the is no folder named IPC2581_CS.  Is there another location or do I have to update/reinstall CS?
    UPDATE: Had to install via Extensions.
