Altium CircuitStudio
  • Altium CircuitStudio
Documents How to Create PCB Templates
  • Author Author: alexsander_altium
  • Date Created: 9 Feb 2018 6:19 PM Date Created
  • Last Updated Last Updated: 6 Oct 2021 9:29 PM
  • Views 3308 views
Creating PCB templates in CircuitStudio is possible but as of now there is not a way to do this within the software. This answer is more of a work around but we are expecting to include this in future release.
To create a template to CircuitStudio here is what you'll have to do:
1. Create your project you want to use as a template
2. Give the project, schematic, and PCB files the same name (file extension can be different)
Example:
MyTemplate.PrjPCB
MyTemplate.CSPCBDoc
MyTemplate.SCHDoc
3. Save these files here: C:\Users\Public\Documents\Altium\CS\Templates\PCB Projects
4. Add to the "PCB Project Templates.ini" file in the same folder as step 3
Using step 2 as an example we would put an entry into the INI as follows
[MyTemplate]
Category=Custom
Title= My custom project template
Description=Starter PCB w/title block, Schematic with Titleblock, Project with options set.
(you can also add an EMF image of the same name if you want a visual preview)
5. Restart / open CircuitStudio
6. Create a new project : File>New Project  Here you should see a custom category in the templates list
  • template
  • circuitstudio
  • jonasschmidt
    jonasschmidt over 5 years ago
    Hi Alexsander,
    I tried your steps but I do not have a "Templates folder", nor a "PCB Project Templates.ini" file. So I manually created them as you described and followed the steps. Unfortunately no success, I only get to see the "Blank" folder with a "Blank PCB Project" when I create a new project. Does the ini file have any content apart from what you wrote? Anything else I can do?
    Thanks in advance!
    CS version 1.5.2
