Altium CircuitStudio
  • Altium CircuitStudio
Documents Tech First Kit-Altium-12-400-NB2DSK01-DB31-FPGA kit
  • Author Author: tech2
  • Date Created: 6 Jan 2010 4:46 AM Date Created
  • Last Updated Last Updated: 5 Apr 2010 9:16 AM
  • Views 2073 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
Altium's NanoBoard architecture is unique in that target programmable devices are housed on separate satellite boards, referred to as daughter boards. These boards plug-in to the NanoBoard. By keeping each programmable device on its own daughter board, engineers can easily change the target project architecture, while retaining a truly FPGA vendor-independent development board.
Altium's AlteraRegistered CycloneRegistered-II daughter board DB31 provides an EP2C35F672C8 device, as well as a range of on-board memories available for use by a design running within that device.
The NanoBoard NB2 provides application-specific plug-in peripheral boards to give complete flexibility in system architecture and provide a simple and cost-effective method for rapid prototyping of hardware concepts.
The NanoBoard NB2 caters for the use of up to three peripheral boards, and is delivered with the following standard peripheral boards:
  • Audio/Video Peripheral Board (PB01)
    • Composite and S-Video output and capture, 24-bit VGA output, high-performance I2S stereo audio codec
  • Mass Storage Peripheral Board (PB02)
    • Compact Flash, SD card slot, ATA hard-drive interfaces
  • USB-IrDA-Ethernet Peripheral Board (PB03)
    • 10/100 Ethernet interface, USB 2.0 interface, 4Mbits/sec IrDA
Kit Contents
Following are included with NanoBoard NB2DSK01:
The NanoBoard NB2 includes a 12-month subscription to an Altium Designer Soft Design license which is linked to the NanoBoard in the box. This license option provides functionality to quickly start designing FPGA-based embedded systems, including:
  • FPGA design entry in C, OpenBus, Schematic, VHDL and Verilog
  • VHDL simulation engine, integrated debugger and waveform viewer
  • Support for a range of 32-bit soft processors for use in FPGA design
  • A rich set of royalty-free IP core libraries including peripherals and user-configurable custom logic
  • Full software development tool chain with libraries and source code
  • Programmable FPGA-based instruments for hardware debug and deployment
  • Support for importing third-party FPGA IP cores, developing and reusing IP libraries
Key FeaturesBack to Top
Key Features of Motherboard Altium NanoBoard NB2:
Following are the Major Features for Altium NanoBoard NB2:
  • Integrated color TFT LCD panel (320x240) with touch screen that facilitates dynamic application interaction.
  • Stereo analog audio system with high-quality on-board amplifiers, mixer, line in/out and stereo speakers
  • Variety of standard communication interfaces – RS-232RS-232 serial, CAN,PS/2 mini-DIN
  • SD card reader – for additional I/O flexibility including the ability to download a variety of files
  • Four channel, 8-bit ADC and 10-bit DAC, I2C-compatible
  • User definable PDA-style push button switches that function as generic design inputs
  • Variety of general purpose switches and LEDs
  • Programmable clock, 6 to 200 MHz, available to target FPGA
  • Power sensing system allows real-time monitoring of system and device power consumption
  • SPI Real-Time Clock with 3V battery back-up
  • Onboard memory accessible by NanoTalk Controller – 256K x 32-bit common-bus SRAM (1MB), 16M x 32-bit common-bus SDRAM (64MB), 16M x 16-bit common-bus 3.0V Page Mode Flash memory (32MB), 256K x 32-bit independent SRAM (1MB)
  • Dual User Board JTAG headers for direct interaction and development on production board
  • Home/Reset button – Home button enables firmware to take control of TFT panel; Reset provides NanoBoard reset functionality
  • NanoTalk Controller – manages real time proprietary communication with Altium Designer, the board, and the NanoBoard firmware using a XilinxRegistered Spartan-3TM (XC3S1500-4FG676C) controller with JTAG accessible Flash configuration PROM
  • Master-Slave connectors for chaining multiple development boards – allowing multiple-FPGA system development
  • Board ID memory – 1-WireRegistered ID system uniquely identifies each daughter board and peripheral board
  • Power – Dual 5V DC power daisy-chain connectors with power switch, 5V DC power output connector, power supply test points for all supply levels available on the board, four GND points
  • High-speed PC interconnection through USB 2.0 allows faster downloading and debugging
The following is a list of generic features, common to NB31 board:
  • Protective casing –all daughter boards have a protective casing that helps protect the topside of the board.
  • 100-way connectors –these 100-way Male docking connectors are used to connect the daughter board to the NB2DSK01 motherboard, which has corresponding 100-way Female docking connectors ('NANOCONNECT' interfaces). Daughter boards available with the Desktop NanoBoard NB2DSK01 and beyond each have three connectors (top, bottom and left). Those available previously for the NanoBoard-NB1 have two such connectors (top and bottom).
  • Power LED –this will light (RED) when the daughter board is correctly plugged into the NB2DSK01 motherboard and the NB2DSK01's power is switched on.
  • Program LED –this will light (GREEN) when the target device on the daughter board has been successfully programmed with an FPGA design.
3-connector daughter boards also have three holes that align with threaded standoffs on the NB2DSK01. These can be used to affix the board securely to the motherboard.
Key Features of Cyclone-II daughter board DB31:
Altium's AlteraRegistered CycloneRegistered II daughter board DB31 provides an EP2C35F672C8 device, as well as a range of on-board memories available for use by a design running within that device.
The DB31 has the following features:
  • Altera Cyclone II FPGA (EP2C35F672C8)
  • On-board memories available for use by FPGA design:
    • 256K x 32-bit common-bus SRAM (1MByte)
    • 16M x 32-bit common-bus SDRAM (64MByte)
    • 16M x 16-bit common-bus Flash memory (32MByte)
    • Dual 256K x 16-bit independent SRAM (512KByte each)
  • WireRegistered memory device used to store board ID and related information
  • Three 100-way connectors for attachment to NB2DSK01 motherboard. These connectors provide:
    • Interface to resources on the NB2DSK01 motherboard and plugged-in peripheral boards
    • SPI bus interface
    • I2C bus interface
    • 1-Wire bus interface
    • JTAG, power and additional control lines from the motherboard.
Ordering InformationBack to Top
Supplier
Part Number
Altium
12-400-NB2DSK01-DB3112-400-NB2DSK01-DB31
Associated Products
Supplier
Description
Part Number
Altium
Cyclone-II
12-401-DB3112-401-DB31
Altium
JTAG USB
12-403-DT0112-403-DT01
ST Micro
Serial SPI Flash Memory
M25P80-VMP6GM25P80-VMP6G
Maxim
RS-232RS-232
MAX3232EUE+MAX3232EUE+
Maxim
Transceiver
MAX3051EKA+TMAX3051EKA+T
Maxim
ADC-IC
MAX1037EKA+TMAX1037EKA+T
Maxim
DAC IC
MAX5841MEUBMAX5841MEUB
Maxim
Current Sense
MAX4372TEUK+TMAX4372TEUK+T
Xilinx
Spartan 3
XC3S1500-4FG456CXC3S1500-4FG456C
Spansion
Flash
S29GL256N11TFI010S29GL256N11TFI010
Maxim
Switch Addressable
DS2406P+DS2406P+
Maxim
Power Supply IC
MAX1831EEE+MAX1831EEE+
Micron
Memory
MT48LC16M16A2P-75:DMT48LC16M16A2P-75:D
Altium
Cyclone III
12-401-DB4012-401-DB40
Altium
Spartan 3AN
12-401-DB4112-401-DB41
Altium
Spartan 3A
12-401-DB4212-401-DB42
Altium
Virtex-4
12-401-DB4612-401-DB46
Altium
Spartan-3
12-401-DB3012-401-DB30
Altium
AUDIO/VIDEO
12-404-PB0112-404-PB01
Altium
MASS STORAGE
12-404-PB0212-404-PB02
Altium
USB / IRDA / ETHERNET
12-404-PB0312-404-PB03
Similar Products
SupplierDescriptionSupport DevicePart Number
Altium
DESKTOP NANOBOARD WITH ALTERA CYCLONE II
Cyclone II
12-400-NB2DSK0112-400-NB2DSK01
Altium
DESKTOP NANOBOARD WITH LATTICE ECP
Lattice ECP
Altium
DESKTOP NANOBOARD WITH XILINX SPARTAN-3
Spartan 3
Altium
NANOBOARD KIT NB2 SPARTAN-3
Spartan 3
12-400-NB2DSK01-DB3012-400-NB2DSK01-DB30
Altium
NANOBOARD KIT NB2, CYCLONE II
Cyclone II
Altium
NANOBOARD KIT NB2, LATTICE ECP
Lattice ECP
12-400-NB2DSK01-DB3212-400-NB2DSK01-DB32
Altium
ALTERA CYCLONE III DB40 DAUGHTER BOARD
Cyclone III
Altium
XILINX SPARTAN-3AN DB41 DAUGHTER BOARD
Spartan 3AN
Altium
XILINX SPARTAN-3A DSP DB42 DAUGHTER BOARD
Spartan 3A
Altium
BOARD, DAUGHTER, DB46, VIRTEX-4 SX
Virtex-4
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
Altera’s Cyclone II series
Cyclone II Handbook
6MB
Cyclone II Datasheet
2MB
DS2406
Dual Addressable Switch Plus 1Kb Memory
240KB
MT48LC16M16A2TG
Common-Bus SDRAM
2.9MB
S29GL256N11FFIV10
Common-Bus Flash memory
4.8MB
MAX8860
Linear Regulator
168KB
MAX1831EEE.MAX1831EEE.
Voltage Regulator
106KB
Application Notes
File Name
Size
AN 479: Design Guidelines for Implementing LVDS Interfaces in Cyclone Series Devices
435KB
AN 357: Error Detection & Recovery Using CRC in Altera FPGA Devices
371KB
AN 114: Designing with High-Density BGA Packages for Altera Devices
574KB
AN 477: Designing RGMII Interface with FPGA and HardCopy Devices
261KB
AN 366: Understanding I/O Output Timing for Altera Devices
311KB
Hardware & Software
File Name
Size
Download the latest release of Altium Designer Viewer
129MB
Download the Altium Instrument Dashboard
31.7MB
Autotrax Freeware Version Download
821KB
Easytrax Freeware Download
485KB
  • at:fpga_kit
  • at:tech_first_kit
  • sp:altium
