Amphenol
  • Amphenol
Amphenol
Amphenol Communication Solutions Blog RotaSense Temperature Sensor Connector: Intelligent Thermal Sensing for Next-Gen Electronics
Join Amphenol to participate - click to join for free!
  • Author Author: Greta_Reilly
  • Date Created: 13 Aug 2025 7:11 PM Date Created
  • Views 643 views
  • Webinar Recap
  • RotaSense
  • Amphenol Communications Solutions
  • FCI Basics
  • acs
Greta_Reilly
Greta_Reilly
13 Aug 2025
In July, Amphenol Communications Solutions hosted a technical webinar presented by Pranith Joy from FCI Basics, highlighting the capabilities, applications, and advantages of the RotaSense Temperature Sensor Connector—a cost-effective, modular, and highly accurate way to sense ambient airflow temperatures in modern electronic systems.
Thermometer️ Precision Ambient Temperature Sensing: Why It Matters
Modern servers, networking hardware, automotive electronics, and industrial systems demand accurate thermal monitoring to maintain performance, prevent overheating, and extend component life.
Traditional sensing methods—such as PCB-mounted SMT sensors or thermistors—often measure board surface temperature rather than actual airflow temperature. This can skew readings, cause fan overspeeding, and waste energy.
RotaSenseTm overcomes this by positioning the sensor directly in the airflow path, enabling true ambient air temperature measurement. This results in:
  • Reduced fan energy consumption without sacrificing thermal safety
  • Improved acoustics through quieter fan operation
  • Extended fan and component life
  • Elimination of costly thermal margining and software-based compensation
Why it matters: False-positive high readings don’t just waste energy—they also increase dust buildup, raise corrosion risks, and can shorten component lifespan.
Wrench Product Design and Engineering Highlights
Two-Piece Modular System
  • Components: Board Connector + Sensor Module
  • Profile height: Just 20.0 mm—ideal for space-constrained designs
  • Mounting flexibility: Three lockable angles (0°, 45°, 90°) for aligning with airflow or accommodating different layouts
Advanced Mechanical & Electrical Performance
  • Dual-beam spring contacts for reliable conductivity and mechanical resilience
  • Contact resistance: < 20 mΩ
  • Rated current: 2A | Voltage: 125V
  • Operating temperature: -40°C to +125°C
  • Withstands 260°C reflow for 10s (SMT termination)
Sensor Technology: 2N3904 NPN Transistor
  • How it works: Base and emitter shorted, collector current applied, measuring V<sub>BE</sub> voltage, which changes linearly with temperature
  • Advantages: Predictable response, easy ADC integration, linear processing, robust against vibration, and cost-effective compared to thermistors
Arrows counterclockwise Application Scenarios: Where RotaSense Excels
Desktop️ IT Datacom Equipment
  • Servers, switches, storage systems
  • Inlet/outlet placement for differential temperature monitoring and dynamic fan control
Oncoming automobile Automotive Electronics
  • Ideal for BMS, inverters, engine control modules
  • Compact, vibration-tolerant, and robust for harsh environments
Zap Energy & Power Systems
  • Solar inverters, UPS, grid monitoring
  • Maintains accurate thermal regulation in variable environments
Industrial & HVAC Systems
  • Smart cooling, refrigeration, precision climate control
  • Direct airflow sensing ensures responsiveness and efficiency
Bar chart Why Choose RotaSense Over Traditional Sensors?
Sensor Type
Common Issues
RotaSense Advantage
On-board SMT sensors
PCB heat interference, poor airflow accuracy
True ambient sensing
Through-hole sensors
Height control, vibration sensitivity, fragile leads
Robust design, lockable angles
Cable-assembly sensors
Placement challenges, heat absorption in wires
Compact, accurate, easy to mount
Question RotaSense Q&A Highlights
Q1: How does RotaSense measure temperature?
A: Using a 2N3904 NPN transistor measuring V<sub>BE</sub> voltage shift with applied collector current—linear, accurate, and ADC-friendly.
Q2: What mounting angles are supported?
A: Three lockable positions—0°, 45°, 90°—for optimal airflow placement.
Q3: What’s the max height when mated?
A: 20.0 mm, ideal for high-density layouts.
Q4: How is accuracy better than PCB or cable sensors?
A: Measures true ambient air, avoiding PCB heat distortion.
Q5: Why choose 2N3904 over thermistors?
A: Linear output, robust integration, cost-effective, and no complex signal correction.
Q6: Key durability features?
A: Dual-beam contacts, high-temp thermoplastic (UL94V0), vibration resistance, 20 mating cycles.
Triangular ruler Engineering Support
Amphenol provides:
  • Mechanical drawings & 3D models
  • Datasheets & performance specs
  • Application-specific integration guidance
  • Reflow profiles
  • Rapid MPN support for design needs
