CamdenBoss
  • CamdenBoss
CamdenBoss
Blog Why Screwless?
Join CamdenBoss to participate - click to join for free!
  • Author Author: M_B
  • Date Created: 10 May 2011 8:13 AM Date Created
  • Views 5389 views
  • screwless
  • hvac
  • cage_clamp
  • terminal_blocks
Why Screwless?
M_B
M_B
10 May 2011
There has been a recent growth in the availability of screwless versions of many of the terminal blocks we offer. Screwless versions of standard PCB terminal blocks such as CSTBV1 have been around for a while and we are now offering screwless pluggables such as CSTB9208 and the very small pitch CSTBA45C.
So what are the advantages of a screwless block?
  • Speed of assembly – to tighten a screw may take 60 seconds. Doesn’t sound like much, but if you have a 20-way assembly, that’s 20 minutes. Instead – just push the wire in and it is trapped in the cage clamp. Can also be used in automated assembly.
  • No screwdriver required. Cross head? Slotted? Combi? No need to carry around bulky screwdrivers. Ideal for ceiling voids and other tricky locations.
  • Maintains pressure on the conductor even in a high vibration application
