Digilent, a National Instruments Company
  • Digilent, a National Instruments Company
Blog Build electronic circuits with Texas Instruments myParts Kit
Join Digilent, a National Instruments Company to participate - click to join for free!
  • Author Author: alexwonglik1
  • Date Created: 26 May 2021 11:51 PM Date Created
  • Views 9054 views
  • photocell
  • mosfet
  • active components
  • circuits
  • flip flop
  • ad converter
  • voltage regulator
  • infrared
  • light sensor
  • power resistor
  • nor
  • rectifier
  • da converter
  • instrumentation amp
  • mux
  • diode
  • op-amps
  • prototype
  • instrumentation amplifier
  • logic gates
  • timer
  • pnp transistors
  • buzzer
  • nand
  • encoder
  • wiring
  • electrolytic capacitors
  • potentiometers
  • resistors
  • switching regulators
  • 555 timer
  • bipolar single transistor
  • passive components
  • comparator
  • inverter
  • transformer
  • counter
  • leds
  • xor
  • flip-flop
  • buffer
  • electronics
  • npn transistor
  • texas instruments
  • ceramic capacitors
  • zener diode
  • voltage regulation
  • decoder
alexwonglik1
alexwonglik1
26 May 2021
Whenever you build a circuit or prototype, the first thing is to grab the necessary components and parts. Occasionally, a missing active or passive component causes a delay for the project. Having the electronic parts kit can prevent this problem. Parts Kits also provide a useful selection of parts that are the building blocks of all electronics.
myParts KitmyParts Kit comes with a collection of parts including op-amps, an instrumentation amplifier, voltage regulators, switching regulators, digital logic gates, timers, temperature sensors, data converters, transistors, resistors, capacitors, LEDs, switches, a wiring kit, and more. With myParts Kit, you can create projects in areas such as power management, audio amplification, spinning motors, light detection, and signal conditioning.
Amplifiers:
  • Op-amps: TL072CP, TL074CN, LF356, LM741C
  • Instrumentation Amp: INA217
  • Comparator: LM311P
Converters:
  • Freq to V converter: LM2917N/NOPB
  • A/D converter, 12-bit: ADS7816P
  • A/D converter: ADS7822P
  • D/A converter, 12-bit: TLV5616CP
Regulators:
  • Inverting switching regulator: MC34063AP
  • Voltage regulator: LM317 (TO-220)
Diodes:
  • Zener diode: 1N4735
  • Small signal diode: 1N3064
  • Fast switching diode: 1N914B
  • 1A Shottky diode: 1N5819
  • 1A rectifier diode: 1N4001
  • Infrared receiver diode
  • Infrared emitter diode
Logic ICs:
  • NAND: triple 3 input (SN74LS10N)
  • NAND: quad 2 input (SN74LS00N)
  • OR: quad 2 input (SN74LS32N)
  • XOR: quad 2 input (SN74LS86N)
  • NOR: quad 2 input (SN74LS02N)
  • AND: quad 2 input (SN74LS08N)
  • Inverter buffer/driver: SN74LS04N Hex
  • Counter, 4-bit: SN74LS163N
  • Dual JK flip-flop: SN74LS107AN
  • D type dual flip-flop: SN74LS74N
  • Decoder/encoder/mux: CD4511BE
  • 3 to 8 decoder/demux: SN74LS138N
  • 8 to 3 encoder: SN74LS148
  • Dual complementary pair/inverter: CD4007UB
  • Timer: TLC555CP
Transistors:
  • P-channel MOSFET (x4): ZVP2110A
  • NPN transistor (x3): 2N3904L
  • PNP transistor (x3): 2N3906L
  • NPN bipolar power transistor: TIP31C
  • PNP bipolar power transistor: TIP32C
  • N-channel power MOSFET: IRF510
  • Compl. transistor pair: STD815CP40 or STD830CP40
  • Dual NPN high voltage transistors: STD845DN40 or STD840DN40
Passive components:
  • Resistors from 1.1Ohm to 10M Ohm
  • Power Resistors 10W, 6.8 Ω, ±5%
  • Potentiometers
  • Ceramic Capacitors
  • Electrolytic Capacitors
  • LEDs
Miscellaneous:
  • Audio transformer
  • Photocell buzzer
  • Light sensor
  • Wiring kit
