Digilent, a National Instruments Company
  • Digilent, a National Instruments Company
Blog Introducing Digilent Zmods: Cost-effective high-speed I/O expansion modules for FPGA boards
Join Digilent, a National Instruments Company to participate - click to join for free!
  • Author Author: alexwonglik1
  • Date Created: 2 Jun 2020 5:55 AM Date Created
  • Views 3288 views
  • bandwidth
  • vivado ip
  • fmc
  • adi
  • zynq 7000
  • programming.
  • zmod dac
  • fpga modules
  • fir
  • xilinx vivado design
  • data acquisition
  • zynq-7000 processor
  • digital to analog converter
  • fpga
  • vivado
  • embedded
  • zmod adc
  • digilent
  • analog devices
  • instrumentation
  • xilinx-linux
  • zynq mpsoc
  • analog to digital converter
  • pmods
  • zmods
  • high speed
  • c++
  • filter
  • zmod
  • software
  • modules
alexwonglik1
alexwonglik1
2 Jun 2020
Many engineers have come across Digilent Pmods standard and even included Pmods in their systems. Pmod modules allow for more effective designs by routing analog signals and power supplies only where they are needed, and away from digital controller boards. However, Pmods aren't for high speed communication. So, engineers can't use Pmods in high speed instrumentation systems or digital signal processing applications. At the same time, high speed FPGA Mezzanine Cards are bulky and comparatively pricey. To solve this problem, Digilent makes use of SYZYGY standard and launch a new line of expansion modules for high-speed control, signal processing, or test and measurement applications
SYZYGY Open Source Standard
Similar to Pmod standard, SYZYGY is an open standard from Portland, Oregon’s Opal Kelly. It fits – in cost, size, and performance – somewhere between the Pmod and FMC standards. Although not much larger than many Pmods, SYZYGY-compatible modules are capable of high-bandwidth connections to an FPGA, enabling very compact and cost-effective high performance I/O. The small, SYZYGY standard form factor recommends them for compact, configurable, rugged systems.
Comparison between Pmod, Syzygy and FMC standard. Source: https://syzygyfpga.io/
Digilent Zmods
Digilent starts the Zmods line with two data acquisition Zmods - Zmod ADCZmod ADC and Zmod DACZmod DAC. The SYZYGY compatible connectors provide enough data transfer bandwidth (BW) for dual-channel, 100MSPS. The high BW and sampling rate, the flexible input/output range, the high resolution and the flexibility provided by the FPGA interface make them ideal for a wide variety of applications.
Zmod ADC 1410
Zmod DAC 1411
A pair of Zmod DAC / Zmod ADC, together with a SYZYGY compatible FPGA carrier, like Eclypse Z7Eclypse Z7, could be used for closed analog loops with digital control, digital filters with analog input and output, hardware-in-the-loop, digital signal processing, high frequency modulators/demodulators, real-time image processing, SDR, etc.
Eclypse Z7 + Zmod ADC + Zmod DAC
Zmods Support Materials
The following tutorials step through the process of creating a hardware platform that supports Zmods.
  • Getting Started with Vivado IP Integrator
  • Adding a Hierarchical Block to a Vivado IPI Design
  • Adding Zmod Support in Petalinux
Digilent provides a set of libraries supporting Zmod modules on both Linux and baremetal (standalone) platforms. The Zmod Base Library implements functionality common to all Zmods. For each Zmod, separate libraries are implemented, based on Zmod Base Library.
    balearicdynamics over 6 years ago +1
    Very interesting modules. I wonder if the DAC module expansion can be used to intergrate some board expanding audio features for syntesis. And what is the best board to do this. Enrico
  • alexwonglik1
    alexwonglik1 over 6 years ago in reply to balearicdynamics +1
    It is possible. You may use Zmod DAC with Eclypse Z7 Zynq SoC Platform / Genesys ZU-3EG Zynq Ultrascale+ MPSoC or any FPGA board with Syzygy connectors
  • alexwonglik1
    Enrico
