Digilent, a National Instruments Company
  • Digilent, a National Instruments Company
Blog Using the Digital Discovery to debug a Character LCD
Join Digilent, a National Instruments Company to participate - click to join for free!
  • Author Author: alexwonglik1
  • Date Created: 8 Apr 2020 1:25 AM Date Created
  • Views 2242 views
  • lcd
  • discovery
  • test and instrumentation
  • test and measurement
  • digital discovery
  • digilent
  • display
  • character display
alexwonglik1
alexwonglik1
8 Apr 2020
Digilent Digital Discovery is a combined logic analyzer and pattern generator instrument and allows you to debug, visualize,
and simulate signals in digital systems. LCD displays are used in a wide range of devices. The most common version uses a 2×16 character array.
You can use Digital Discovery to understand the operations of the LCD display. To do so, you need the following hardware and software.
Hardware
  1. Digital Discovery
  2. HD44780 LCD + Arduino LCD Keypad Shield
  3. Arduino Uno
Software which can be downloaded in Digilent Wiki
  1. Arduino Sketch
  2. Digilent Waveforms multi-instrument software application
Then, you can plug the HD44780 LCD on LCD Keypad shield and stack the module on the Arduino Uno. You also need to download the sketch to the Arduino board. After that, you need to connect the Digital Discovery to the HD44780 LCD. The below picture shows the hardware set-up.
Scopes digital signals in Logic Analyzer
After you open WaveForms software and turn on Logic Analyzer instrument, you can add the following signals and buses
  1. RS signal as a separate signal and set trigger mode to normal with triggering on a rising edge of the EN signal
  2. Clock signal
  3. A nibble data bus with a clock on the rising edge of the EN signal
You can try different command and look at each bus and signal. When commands of 0x01 (“clear display”) and data 0x50 (letter “P” encoded in ASCII) are sent, you can see the LSB and 3rd bit are driven respectively.
Go through the step by step guideline and get the example code in the Digilent Wiki
    dubbie over 6 years ago +1
    Looks a very nice, comprehensive and (relatively) low cost system. Regretfully it is still too expensive for me, I'll have to stick with my existing DSO and brain power. I get there in the end, it just…
    Looks a very nice, comprehensive and (relatively) low cost system. Regretfully it is still too expensive for me, I'll have to stick with my existing DSO and brain power. I get there in the end, it just takes longer.
    Dubbie
