Fluke
  • Fluke
Fluke
Blog 10 dumb things smart people do when testing electricity
Join Fluke to participate - click to join for free!
  • Author Author: flukeltd
  • Date Created: 5 Dec 2018 9:58 AM Date Created
  • Views 10610 views
  • Comments 13 comments
  • fluke dmm
  • dmm
  • Digital Multimeters
  • fluke;
  • multimeter
  • fluke
  • safety
flukeltd
flukeltd
5 Dec 2018
We identify the 10 most common mistakes even expert electricians can make when testing electricity.
Anyone who makes their living by working with electricity quickly develops a healthy respect for anything with even a remote chance of being “live.” Yet the pressures of the getting a job done on time or getting a mission-critical piece of equipment back online can result in carelessness and uncharacteristic mistakes by even the most seasoned electrician. The list below was developed as a quick reminder of what not to do when taking electrical measurements.
  1. Replace the original fuse with a cheaper one. If your digital multimeter meets today’s safety standards, that fuse is a special safety sand fuse designed to pop before an overload hits your hand. When you change your DMM fuse, be sure to replace it with an authorised fuse.
  2. Use a bit of wire or metal to get around the fuse altogether. That may seem like a quick fix if you’re caught without an extra fuse, but that fuse could be all that ends up between you and a spike-headed your way.
  3. Use the wrong test tool for the job. It’s important to match your DMM to the work ahead. Make sure your test tool holds the correct CAT rating for each job you do, even if it means switching DMMs throughout the day.
  4. Grab the cheapest DMM on the rack. You can upgrade later, right? Maybe not, if you end up a victim of a safety accident because that cheap test tool didn’t actually contain the safety features it advertised. Look for independent laboratory testing.
  5. Leave your safety glasses in your shirt pocket. Take them out. Put them on. It’s important. Ditto insulated gloves and flame-resistant clothing.
  6. Work on a live circuit. Ensure the installation is isolated and proven dead before you start working.
  7. Fail to use proper lockout/tag-out procedures.
  8. Keep both hands on the test. Keep one hand in your pocket. Accidents can occur and this lessens the chance of a closed circuit across your chest and through your heart. Hang or rest the meter if possible. Try to avoid holding it with your hands to minimise personal exposure to the effects of transients.
  9. Neglect your leads. Test leads are an important component of DMM safety. Make sure your leads match the CAT level of your job as well. Look for test leads with double insulation, shrouded input connectors, finger guards and a non-slip surface.
  10. Hang onto your old test tool forever. Today’s test tools contain safety features unheard of even a few years ago, features that are worth the cost of an equipment upgrade and a lot less expensive than an emergency room visit.
For more information on the products and services available from Fluke, click here.
  • snidhi
    snidhi over 7 years ago +6
    The discussion on cheap DMMs is never ending. I tried to convince some companies in the electronics business to stay away from cheap made DMMs. And rather invest in good DMMs such as fluke ones as they…
  • 14rhb
    14rhb over 7 years ago +5
    Useful advice, thank you. The flurry of Fluke related pdfs currently also make great reading. Rod
  • Sean_Miller
    Sean_Miller over 7 years ago +4
    Great list. I'd throw in not knowing the limits of the amperage to run through the meter when measuring current in industrial applications. -Sean
  • flukeltd
    flukeltd over 7 years ago in reply to mudz
    Hi mudz,
    Thanks for reaching out!
    We'd like to clarify that this article is talking
    about other older, non-compliant DMMs that are still in  use today. This
    doesn't include your 87v, which continues to  comply with current
    safety standards.
    Depending on your application, the 289 would be the
    "better" and "more modern" solution, but the 87V is indeed
    the most popular.
    We hope we've answered your question! Thanks for
    being a loyal Fluke user.
    Best,
    Fluke Team
  • mudz
    mudz over 7 years ago
    flukeltd
    Today’s test tools contain safety features unheard of even a few years ago, features that are worth the cost of an equipment upgrade?
    Like what?
    Are you saying there something better then multi meter 87 v because this equipment is old but trusted one. Have you upgraded this one with modern safety features you are talking about?
    Thank you
  • gadget.iom
    gadget.iom over 7 years ago in reply to Gough Lui
    Strongly agree with point 3.
  • s8548a
    s8548a over 7 years ago
    Point #1 used to do when in the beginning, and later such circumstances were become rare.
  • Gough Lui
    Gough Lui over 7 years ago in reply to 14rhb
    14rhb - can't agree with you more there - tools or test equipment - I very much make sure I keep an eye on and don't usually lend it out because more often than not, it is abused, stolen etc. At most, I let someone else use it while I supervise ... that's not to say I don't make my own mistakes but if I do ... I only have myself to blame.
    - Gough
