Fluke
  • Fluke
Fluke
Forum Problem with old Fluke Scopemeter
Join Fluke to participate - click to join for free!
  • Replies 22 replies
  • Subscribers 25 subscribers
  • Views 11904 views
  • fluke scopemeter
  • fluke 123
mudz
mudz over 7 years ago
Today, I received my most awaited thing of this year... After a long long journey it finally reach me.. Hehe ..  enough with suspense talk..
Few months ago like 5 months.. I bid for a scopemeter on ebay. This was the first time I did bidding thing. Okay, what stupid thing I did now...  Alright, Bidding shot up to almost double and I ended up buying this Fluke 123 Scopemeter which has a line on the display image  image
Now after being stuck to customs for almost four months due to no invoice, I finally got the parcel and paid 40% custom duty. image
This thing cost me fortune I could have purchased a nice 2 channel oscilloscope. Stupid me.. (probably till now shabaz will be thinking, this guy is idiot I warned him many times before but he doesn't even listen).. image
Now, this meter is not turning on, I believe after 5 months of no activity battery is probably dead. So I thought to charge it first. There is always a but.. When I checked its adaptors output voltage it is 22.3 volts when it should be 15 volts.
Anyone already has this scopemeter? Should I charge it with it? ebay sender told me it was working when he send me the item, but did not about voltages.
  • Gough Lui
    Gough Lui over 7 years ago +6
    Is this a "heavy" wall-wart adapter? I suspect it might be a regular unregulated linear power supply. With old fashioned linear power supplies which are *unregulated*, the voltage will approximate the…
    michaelkellett over 7 years ago +5
    You've got a modern flashy one ! Mine is a PM97 made by Philips (before Fluke bought the Scopemeter line from them). Don't know exactly how old but the calibration sticker is dated 2002 ! I haven't used…
    michaelkellett over 7 years ago in reply to mudz +5
    Never used it much, and haven't for more than 15 years. It's just not good enough (50MHz, not much memory) for the kind of work I mainly do - so I often end carrying a bench scope about. Got it from where…
  • mudz
    mudz over 7 years ago in reply to shabaz
    Hi shabaz, Charger that comes with it is currently plugged in to the scopemeter.
    Last night, I tried powering it once again and it powered on while still connected to power, so I played with it for few minutes. I charged it for more than a hour and tried turning it on again, it turned on but immediately battery showed X mark on it. Now, I've put that scopemeter in its refresh battery mode, it will take 12 hours then only I can use it again, almost 4 hours left now. Refresh cycle charges battery to full and then discharges it.
    Once Refresh cycle ends, I'll post what happens. But my suspicions are battery will take more time to charge now or even doesn't charge, as it's pretty dead and you have cleared my doubts on that part.
    On the Ni-MH not charging issue, I believe you're quite right, this is what needs to be done. I've my suspicion that battery is not charging even after charging it for 2-3 hours yesterday on different occasions. I'll try charging it manually after refresh cycle is complete, who knows refresh cycle thing is even working screen is just black like not on.
    Refund thing will not work as it is too late for it now and I know what I was getting, a used scopemeter with few lines on display, seller was quite helping actually. Even if battery is dead I can buy new one and replace it.
    Here are few pics i took when it was alive:
    • Vote Up +5 Vote Down
  • fmilburn
    fmilburn over 7 years ago
    You may be aware of this but there a couple of videos by Dave Jones where he repairs the "zebra" strip that can cause lines to not display on a LCD.  Here is one of the videos: https://www.bing.com/videos/search?q=eevblog+lcd+repair&view=detail&mid=44F6F479982EBE0FB0B044F6F479982EBE0FB0B0&FORM=VI…
    In this video he refers to repair of Fluke handheld scope so you might look for that one.
  • mudz
    mudz over 7 years ago in reply to fmilburn
    Hi fmilburn, I am aware of this problem and this is common problem with this type of meters, I knew it can be repaired that is why I purchased this meter. This problem is due to soldering joints between pcb and lcd cable. I was only hoping for seller did not have already tried to do this repair and did not make a mess inside it.
    So I'll be opening it soon after resolving this battery problem I'm currently facing.
    Thanks for the link.
  • mudz
    Alright, First things first, battery refresh cycle failed. I charged it for almost whole day now, and it still showing very low battery bar. I'm thinking of removing back cover and checking battery voltage. hmm
    Will update soon.
  • mudz
    mudz over 7 years ago in reply to mudz
    it's getting more interesting. This is my findings on battery so far:-
    There is no marking on battery not even NiMH or NICd written anywhere just plain blue.
    So it seems past owner has replaced it with some other then OEM battery.
    Battery voltage between red and black wire is ~5.514v and yet meter shows bar at lowest level, probably if I run it for few more minutes it will switch off.
  • Robert Peter Oakes
    Robert Peter Oakes over 7 years ago in reply to mudz
    The other responses are correct, if this is a basic linear supply (Rectified and smoothed but not regulated, which was very typical in this kind of supply, and why you see that dashed DC line on the label) then on no load, it is possible to have an output sitting at the peak voltage of the sine wave.
    the supply is probably not the actual charger, just the raw supply for it, the charging circuit will be inside the meter.
    If you want to be sure before you connect it, just load it upto the rated 300mA and see what it reads then, or connect a true 15V dc supply to the meter
    hope this helps
    Peter
    Safety Circuit..... image... probably not
    cheapest... one diode, next level 2 diodes in a half bridge but requires a center tap transformer which is more expensive, the better would have 4 diodes AKA "FULL BRIDGE RECTIFIER", imaging the rolling mono brow if you get the reference image
    so even skipped the simple smoothing cap, so if you had 4 diodes and a cap, your doing really well, if it included a thermal fuse then it was getting close to medical grade lol.
    probably no soldering needed, just resetting the zebra strips if your lucky
    Zebra strips use physical contact only with a little pressure. they are not soldered to the LCD or PCB
  • mudz
    mudz over 7 years ago in reply to Robert Peter Oakes
    How to do this?
  • jamesw2965
    jamesw2965 over 7 years ago
    Wow, that was some story. From what I know of Fluke you can send it to them to have it fixed. I would first encourage you to look up your fluke device and get all the information on it. I would then download the manual and see if the charger you have is a fluke charger. Second, inquire about having the fluke item checked. If you paid that much for it, you might as well go the distance and make sure it's in perfect working condition.
    Good luck.
    jamesw
