Intel
  • Intel
Intel
Forum MRAA and I2C Display
Join Intel to participate - click to join for free!
  • Answers 2 answers
  • Subscribers 5 subscribers
  • Views 2023 views
  • arduino_breakout
  • gpio pinout
  • lcd_screens
  • mraa
  • i2c_conflicts
  • intel edison
vandia
vandia over 9 years ago
Pastebin URL: https://pastebin.com/QgCNn7eD
Anyhow, I'm using the SSD1306 I2C screen module. I'm programming in Python, and have it working pretty well, for the most part.hat is,
Until I try to use MRAA to read analog inputs. Suddenly, the screen will not turn on.
With the commented section commented, the screen turns on. Uncommented, it turns off, even though the code still runs in the terminal.
Has anyone else had this problem, is it documented somewhere, or is something else wrong that I'm doing, involving using both?
  • Workshopshed
    Workshopshed over 9 years ago +1 suggested
    There are shared pins on the Edison, is that analogue pin used for something else? Have you tried a different pin?
  • Workshopshed
    Workshopshed over 9 years ago in reply to vandia +1 suggested
    Perhaps in the hardware guide for the Edison breakout? There are ways to emulate an analogue pin with two digital pins and a timer if you need or an external A-D chip
  • vandia
    vandia over 9 years ago in reply to Workshopshed +1 verified
    So, according to: http://www.intel.com/content/dam/support/us/en/documents/edison/sb/edison-arduino-hardware-guide.pdf Don't use Analog 5/6 if you plan to use I2C, they both use the same Arduino pin. This…
  • Workshopshed
    0 Workshopshed over 9 years ago
  • vandia
    0 vandia over 9 years ago in reply to Workshopshed
    Thanks for the reply!
    I actually just thought of that idea literally less than 5 minutes ago.
    Is there a list of shared pins? I'm not really used to the concept, except for also controlling an LED.
    I'm using analog pin 5, for the record.
    My problem with this is, what's the easiest/cheapest way to use multiple analog inputs then, in Python?
    I'd like to reserve 4 for the Compound Eye later, but apparently need 4 analog inputs for that, while there's only 5 on the Edison...
    I'll try to get back to the Edison and this idea tomorrow, in the meantime. ^_^
  • Workshopshed
    0 Workshopshed over 9 years ago in reply to vandia
  • vandia
    This seems to be a thing with the Atmega chip, not the Edison itself.I hope this helps someone in the future!
    For Future Search Results of others:
    Can't Read Analog while using I2C because shared pin on Arduino Edison
    Above is worded in a way search engines would recognize it, please excuse the grammar, normal folks!
    I sincerely thank you for your input, Andy! But since I already thought of that, and had to find the documentation myself, I'm marking this the correct answer for having a direct reference to conflicting pins (and changing tags).
