Microchip
  • Microchip
Microchip
Forum clock setup about dsPIC33F !
Join Microchip to participate - click to join for free!
  • Subscribers 26 subscribers
  • Views 2224 views
sam
sam over 17 years ago
Can someone please help me with this code. I'm trying to get the dsPIC33FJ256GP710 (Explore 16) to run at 40Mhz. This is part of the code I've found but it gets stuck at the line "while (OSCCONbits.COSC != 0b011); // Wait for Clock switch to occur". ie it's not switching. It did give me a warning saying something about cycling power before starting, but me no comprendo.
_FOSCSEL(FNOSC_FRC);      // FRC Oscillator
_FOSC(FCKSM_CSECMD & OSCIOFNC_OFF  & POSCMD_NONE);
_FWDT(FWDTEN_OFF);              // Watchdog Timer Enabled/disabled by user software
int main(void)
/* Configure Oscillator to operate the device at 40Mhz */
// Fosc= Fin*M/(N1*N2), Fcy=Fosc/2
// Fosc= 7.37M*43(2*2)=80Mhz for 7.37M input clock
PLLFBD=41;     // M=43
CLKDIVbits.PLLPOST=0;  // N1=2
CLKDIVbits.PLLPRE=0;  // N2=2
OSCTUN=0;     // Tune FRC oscillator, if FRC is used
// Disable Watch Dog Timer
RCONbits.SWDTEN=0;
// Clock switching to incorporate PLL
__builtin_write_OSCCONH(0x03);  // Initiate Clock Switch to Primary
            // Oscillator with PLL (NOSC=0b011)
__builtin_write_OSCCONL(0x01);  // Start clock switching
// Wait for PLL to lock
while(OSCCONbits.LOCK!=1) {};
  • awinning
    awinning over 17 years ago
    Hi Sam, I moved the thread to the Microchip section. I know the guys are pretty active here
  • AlexLuFarnell
    AlexLuFarnell over 17 years ago
    Thus you don't need most of your code at all because you can use a single speed startup. Just set _FOSCSEL(FNOSC_FRCPLL); and initialize your PLLFBD and CLKDIV registers to the values you posted above. You may also skip the OSCCON.LOCK wait loop if your time critical section does not start within first few milliseconds after power up. BTW the OSCCON.LOCK wait loop may be simulated incorrectly in MPLAB thus making you think that your code hangs - in real MCU it runs as expected.
  • lightng
    lightng over 12 years ago
    Hi  !   Sam,
    Just a note regarding "cycling power before starting" it may mean removing power and re-powering for a new start of the application in order to make it work as it should in some cases.
    Lightng
