Microchip
  • Microchip
Microchip
Forum pic18 free compiler
Join Microchip to participate - click to join for free!
  • Subscribers 26 subscribers
  • Views 869 views
pic18 free compiler
Good morning !
I want to start working with PIC18F14K50-I/MQPIC18F14K50-I/MQ.
Can you suggest me some free C compiler for this PIC (even if there are limitations)?
Does Hitech provide such free compiler as for PIC10/12/16?
I have got PICKit3  with MPLAB: it is able to program such micro?
Thanks a lot
RGB
    Hi RGB,
    You can download free PIC18 compiler from Microchip website. Please find below link for the same
    http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en010014
    Download the latest version of MPLAB IDE from microchip website and install the same. And follow the following steps to check whether the device supports or not with PICKIT3.
    Steps
    1) open MPLAB IDE
    2) Select Configure Device  --->> Select Device ( Select your pic18F14FK50  from drop down list)
    3) Check below in programmer. If  In front of PICKIT3 if grren color indidcates means it suppots that device.
    If any futher query feel free to contact us.
    Best Regards
    Chitra K
    Product Engineer
    Email : chitrak@farnell.com
  • edmund
    edmund over 17 years ago in reply to e14 Contributor
    Hi RGB,
    do give it a try. I have tried that approach and is fantastic...
    Cheers
    Edmund
    Hi RGB , the only limitation on our 'free' C compilers is that of optimization , in other words , the free version may not generate quite such tight code - it all depends upon what you are doing , most people think it's great . The PICKit 3 should program the 18F14K50 parts fine .
    Cheers , Mike
