Microchip
  • Microchip
Microchip
Forum DSPIC30F4011
Join Microchip to participate - click to join for free!
  • Subscribers 25 subscribers
  • Views 433 views
  • microchip
  • 16_bit
  • microcontroleur
DSPIC30F4011
hello
i m have big probleme with a DSPIC30F4011
we delopped an electronic ignition for VHC car
i m have no response in the web and i m need to finisch this project before tomorow
could you help us
we make more test
and is the pic who lost the signal in OC1 and put all impuls in OC3
if we put out the coil who was connected at OC3 we refined the good signal on the two OC
if we deconecte the  coil attached to OC1 we have change in OC3
we have 1 optocoupleur and 3 darlington transistor to isolate the pic from the coil
best regards
schéma.DSN.zip
  • enrico.migchels
    enrico.migchels over 16 years ago +1
    Hi Vincent, Please start the post with a proper schematic in PDF-form or other easy viewable format. Best regards, Enrico Migchels
  • enrico.migchels
    Hi Vincent,
