Microchip
  • Microchip
Microchip
Forum clé USB
Join Microchip to participate - click to join for free!
  • Subscribers 28 subscribers
  • Views 1529 views
clé USB
bonjour,
je voudrait faire une clé usb a partir d'un micro type PIC18F2550 avec une mémoire.
je pense que ce composant correspondrait a ce type d'application pourriez vous me le confirmer ?
existerait il des schémas et du soft déja existant directement utilisable pour ce type d'application "classique "?
merci par avance
K. PHILIPPE
  • koh
    0 koh over 17 years ago
    Hi k.philippe,
    Will it be possible to translate it to english wordings?
  • edmund
    0 edmund over 17 years ago in reply to koh
    Dear Koh,
    you can translate the message using the google translator located at the top right hand corner of the webpage. Here is the translated version:
    would like to make a USB key was using a PIC18F2550 micro-type with a memory.
    I think this component would correspond to this type of application can you confirm me?
    are there any patterns and soft already existing directly usable for this type of application "classic"?
    thank you in advance
    Cheers
    Edmund
    0 e14 Contributor over 17 years ago in reply to edmund
    Hi Edmund,
    Thanks for Sending our Query.
    I would like to recommend Two devices for your application.
    PIC18F2450  ( This is cost effective with less pins)
    http://uk.farnell.com/jsp/search/browse.jsp;jsessionid=VB2H34KYM3UCWCQLCIPJN4Q?N=0&Ntk=gensearch_001&Ntt=PIC18F2450&Ntx=&suggestions=false&searchTerm=PIC18F2450&_requestid=456641
    http://www.newark.com/jsp/search/browse.jsp?N=500003+1001919&Ntk=gensearch_001&Ntt=PIC18F2450&Ntx=
    PIC18F2550
    http://uk.farnell.com/jsp/search/browse.jsp;jsessionid=VB2H34KYM3UCWCQLCIPJN4Q?N=0&Ntk=gensearch_001&Ntt=PIC18F2550&Ntx=&suggestions=false&searchTerm=PIC18F2550&_requestid=456769
    http://www.newark.com/jsp/search/browse.jsp?N=500003+1001919&Ntk=gensearch_001&Ntt=PIC18F2550&Ntx=
    Plz find the below Microchip Link for USB Application.
    http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1469
    If any further query feel free to contact us.
    Best Regards
    Chitra K
    Product Engineer
    Hi , apologies for my delay in getting back to you , our lowest cost USB part that could meet your needs is the new PIC18F13K50 , by key I guess you mean something like a dongle ?  Essentially all you need is  for the PIC  to enumerate to the PC when it is inserted .
    Please check out the user guide for the low pin count USB starter kits . More info can be found at :
    http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en536385
    Regards , Mike
  • MicrochipRTCfr
    0 MicrochipRTCfr over 17 years ago in reply to e14 Contributor
    Bonjour,
    Il est tout à fait possible de faire une clé USB à partir d'un PIC connecté à une mémoire.
    La pile de protocole USB de Microchip est gratuite et peut-être téléchargée ici : http://www.microchip.com/USB
    Après installation sur votre PC vous trouverez une multitude de projets tous faits dans le répertoire C:\Microchip Solutions dont les projets suivants :
    C:\Microchip Solutions\USB Device - Mass Storage - SD Card data logger\
    ou aussi :
    C:\Microchip Solutions\USB Device - Mass Storage - Internal Flash\
    Il faudra cependant choisir un PIC18 avec plus de mémoire.
    Les projets disponibles dans la pile logicielle USB fonctionnent sur des cartes Microchip en vente dont vous pouvez télécharger les schémas sur le site Microchip.
    Nous proposons régulièrement des formations en France sur l'USB : http://www.microchip.com/RTC
    Salutations
