Molex
  • Molex
Molex
Blog How To Build a Coeur CST High Current Interconnect System
Join Molex to participate - click to join for free!
  • Author Author: rscasny
  • Date Created: 16 Sep 2019 4:17 PM Date Created
  • Views 13340 views
  • molex
  • coeur cst high-current interconnect system
rscasny
rscasny
16 Sep 2019
Once you determine the pitch, mounting style, and maximum current per contact, select from the list below:
Contact Pin
Screw-In Mounted
Coeur CST High-Current Male Screw-Mounted Pin, 6.00mm Diameter, 25.50mm Length, 140A, 600V Click to Learn More
Coeur CST High-Current Male Screw-Mounted Pin, 8.00mm Diameter, 26.15mm Length, 200A, 600V Click to Learn More
Press-Fit
Coeur CST High-Current Male Press-Fit Pin, 3.40mm Diameter, 26.00mm Length, 75A, 600V Click to Learn More
Coeur CST High-Current Male Press-Fit Pin, 6.00mm Diameter, 26.00mm Length, 140A, 600V Click to Learn More
Coeur CST High-Current Male Press-Fit Pin, 8.00mm Diameter, 26.00mm Length, 200A, 600V Click to Learn More
Surface-Mounted
Coeur CST High-Current Male Surface Mount Pin, 3.40mm Diameter, 20.00mm Length, 75A, 600V Click to Learn More
Coeur CST High-Current Male Surface Mount Pin, 3.40mm Diameter, 14.00mm Length, 75A, 600V Click to Learn More
Coeur CST High-Current Male Surface Mount Pin, 6.00mm Diameter, 20.00mm Length, 140A, 600V Click to Learn More
Coeur CST High-Current Male Surface Mount Pin, 6.00mm Diameter, 31.75mm Length, 140A, 600V Click to Learn More
Socket
Press Fit
Coeur CST High-Current Female Press-Fit Socket, 3.40mm Diameter, with 1.00mm Float, 75A, 600V Click to Learn More
Coeur CST High-Current Female Press-Fit Socket, 6.00mm Diameter, with 1.00mm Float, 140A, 600V Click to Learn More
Coeur CST High-Current Female Press-Fit Socket, 6.00mm Diameter, 140A, 600V Click to Learn More
Coeur CST High-Current Female Socket, 8.00mm Diameter, with 1.00mm Float, PressFit, 200A, 600V Click to Learn More
Coeur CST High-Current Female Socket, 8.00mm Diameter, Press-Fit, 200A, 600V Click to Learn More
Surface Mounted
Coeur CST High-Current Female Surface Mount Socket, 3.40mm Diameter, 75A, 600V Click to Learn More
Coeur CST High-Current Female Surface Mount Socket, 3.40mm Diameter, with 1.00mm Float, 75A, 600V Click to Learn More
Coeur CST High-Current Female Surface Mount Socket, 6.00mm Diameter, 140A, 600V Click to Learn More
Coeur CST High-Current Female Surface Mount Socket, 6.00mm Dia., with 1.00mm Float, 5.17mm Height, 140A, 600V Click to Learn More
Coeur CST High-Current Female Socket, 8.00mm Diameter, Surface Mount, 200A, 600V Click to Learn More
Coeur CST High-Current Female Socket, 8.00mm Diameter, with 1.00mm Float, Surface Mount, 200A, 600V Click to Learn More
Crimp
Coeur CST High-Current Female Crimp Socket for 1/0 AWG Click to Learn More  or Part Detail
Housing
Coeur CST High-Current Female Crimp Housing Click to Learn More or Part Detail
Coeur CST High-Current Female Terminal Retention Housing Click to Learn More or Part Detail
Coeur CST High-Current Male Header, 2 Circuits, Screw Attach Click to Learn More or Part Detail
