Molex
  • Molex
Molex
Blog I thought nobody used Morse code anymore?
Join Molex to participate - click to join for free!
  • Author Author: MolexConnectors
  • Date Created: 13 Dec 2010 8:37 PM Date Created
  • Views 826 views
  • connectors
  • molex
  • interconnect
  • connector
  • interconnects
  • power
MolexConnectors
MolexConnectors
13 Dec 2010
imageWhen I first got involved in Power connectors, one of the first things I noticed was there were a lot of “hybrid” connectors. Meaning a single connector had both power and signal contacts. At first I panicked. Omigosh, I thought. I am not only going to have to catch up on the power connector market after working in other connector markets for 20 years, but I was faced with learning about signal integrity. Terms like skew, FEXT and insertion loss danced through my head.
I quickly learned that these so called signal lines are running at rates that, to the backplane guys, are like comparing the hare to a dead tortoise! These are basically go, no go circuits, which are also borrowed for lower current usage. In fact, in the first four years I talked with customers, only one time did an engineer ask me about the signal speed of our hybrid power connectors.  Now usually a signal integrity engineer will load up models run on unbelievably complicated software and high-end computing machines and then spit out more squiggly lines than a Boston street map! But when I handed my engineer a sample of our power connector and asked him about speed, he just looked at it and said 600 mhz and it would be a waste of time to try to get more accurate. He also said that at that speed they don’t call it insertion loss, they call it resistance!  Now I don’t know if that is going to change and suddenly we’ll be asked to put 2 Gbps signal products in with the higher current products we are developing. But when it does, at least I now understand FEXT, NEXT and skew!>Read More From The Connector by Molex: http://www.connector.com/2010/10/i-thought-nobody-used-morse-code-anymore/#ixzz181gwXAGL
