Molex
  • Molex
Molex
Forum Dual in line pin header
Join Molex to participate - click to join for free!
  • Replies 7 replies
  • Subscribers 13 subscribers
  • Views 1680 views
peranders
peranders over 16 years ago
https://www.elfa.se/elfa3~se_en/elfa/init.do?shop=ELFA_SE-EN#toc=20459;item=48-148-44;
Has Farnell any similar product? The purpose is a SO08 -> DIL08 adapter.
http://www.precidip.com/data/files/pdf/products/dil-sil-to-sockets_en.pdf
page 145
  • peranders
    Bump. Anyone who knows?
  • peranders
    peranders over 15 years ago in reply to peranders
    I raise the question again. I'm quite convinced of that Farnell has this item but what is it called?
    https://www.elfa.se/elfa3~se_en/elfa/init.do?item=48-148-44&toc=20459
    My first link in the first post isn't valid anymore.
    e14 Contributor over 15 years ago in reply to peranders
    Hi Peranders.
    Try something like this and cut it to fit.
    http://uk.farnell.com/samtec/bbl-108-t-f/header-2-54mm-lo-pro-way8/dp/1765363
  • peranders
    peranders over 15 years ago in reply to e14 Contributor
    This will fit for one of my designs but it's a plus if the pins are fixed in two rows. See picture below.
    http://sjostromaudio.com/hifi_pics/hifi_100pr/adp01-04.jpg
  • Malcolm
    Malcolm over 15 years ago
    Hi, Cant see an 8 pin DIL through header (we do the 16 pin Farnell part number 177854). You mentioned that the purpose was for "The purpose is a SO08 -> DIL08 adapter", we do an adapter SOIC to DIL Farnell part number 1136592 which may be of interest. http://uk.farnell.com/aries/08-350000-11-rc/adaptor-soic-to-dil-8way/dp/1136592?Ntt=1136592  Regards Malcolm
    FEC only do a 14w and 16w "Dil Through Header". Other than that you can find them on "another" suppliers website *LINK*
  • peranders
    I want this as the link pointed out but it seems that Farnell only has 14 pins as minimum. OK, you could cut it. My other supplier is ELFA but I thought it would be nice if Farnell had this socket.
    Thanks anyway guys!
