Molex
  • Molex
Molex
Forum So what’s the big deal about halogens?
Join Molex to participate - click to join for free!
  • Subscribers 11 subscribers
  • Views 944 views
  • connectors
  • pvc
  • halogen
  • molex
  • cfr
  • interconnect
  • bfr
MolexConnectors
MolexConnectors over 15 years ago
Halogen-Free.  Low-Halogen.  BFR-free.  PVC-Free.  BFR/CFR/PVC-Free.  What?
The electronics industry is all abuzz about removing certain  substances – that aren’t even (currently) regulated in any country!   What’s the big deal?  Why are we spending so much money to change  products to other, more-expensive, materials, when the original  materials ‘work’ just fine?  Let’s first look at the concerns with these  groups of substances, then talk about alternatives and what Molex is  doing.
Brominated and Chlorinated Flame Retardants (BFR/CFR)
Flame retardants are used in plastics to reduce fire from spreading  (bet you couldn’t figure that out from their name!).  If the plastic  component can’t burn well, then the fire can’t burn as quickly.  If a  fire starts in your home television and spreads to the rest of your  home, you’ll want to get out as quickly as possible.  These flame  retardants in Molex connectors slow the spread of fire, potentially  preventing the fire from spreading to the rest of your home, or allowing  you those crucial extra moments to escape safely.  So what could  possibly be bad about these helpful substances?
Well, many consumer electronics have a short life-span, and none of  us want electronics to end up in landfills.  When electronics are  recycled, the materials need to be segregated by type – this allows the  materials to be recycled and reused more efficiently.  Plastics go with  similar plastics; metals go with similar metals.  Many plastics are  burned, and if this process is not performed properly, hazardous dioxins  and furans could form from the brominated or chlorinated flame  retardant.  Get rid of the brominated or chlorinated flame retardant,  and get rid of that problem, right?
Polyvinyl Chloride (PVC)
PVC is a polymer that is used primarily in cables, but also other  components.  Phthalates are a group of substances added to PVC to make  the cables flexible.  Plugging a rigid power cable from your mobile phone to the wall outlet wouldn’t work well!   Flexible PVC allows the cable to bend.  So what’s the big deal?
Well, disposal or burning of cables can also generate hazardous  dioxins and furans.  In addition, phthalates have been found to be  dangerous, and some countries regulate phthalates in toys and medical  devices.  Replacing PVC with an alternative will remove both of these  potential hazards.
What are the alternatives?  What is Molex doing?  We’ll discuss this in a future environmental blog post.
Read More From The Connector by Molex: http://www.connector.com/2010/08/409/#ixzz16ht5CnUt
  • jvdberg@ieee.org
    jvdberg@ieee.org over 15 years ago
    What is worse for the environment?
    A building that is completely destroyed by a fire or equipment that will give you time to extinguish a beginning fire or only cause a bad smell?
    If a building is burned down, poisenous smoke might come from other objects and pollute the environment. To replace everything that was lost in the fire, making new equipment will pollute the environment. Even if the most green production techniques are used.
    I think the only good alternatieve for flame retardants in plastics is not using plastic. Insulators could be made of ceramics or glass. Enclosures could be made of (unpainted) metal. But how to make electronic circuits this way?
    If not using flame retardants is more polluting than using them, I think we must not ban the use of them.
  • MolexConnectors
    MolexConnectors over 15 years ago in reply to jvdberg@ieee.org
    Hello, We will be posting a new blog article titled "Pros and Cons of Eliminating Hazardous Substances" next week. This will address most of the questions and comments you had here. Stay tuned!
