Molex
  • Molex
Molex
Forum Searching for the right connectors
Join Molex to participate - click to join for free!
  • Subscribers 10 subscribers
  • Views 594 views
Hi!
for a small hobby project we need some wire-to-wire connectors which should also be able to be used as wire-to-board without changing the plug on the wire side when we switch from development to production board. Could this be done with the Molex SL series? Could someone of you give me some sets of product numbers for 2, 3 and 4 pin versions, as well as the needed crimp terminals which would work together? Maybe in a table like this:
wire sidewire/board side
wire housingcrimp terminalwire housingcrimp terminalPCB
00505794040016020105070107000300160201080705430038
Standard tin plating for 24-30 AWG is enough. My table contains the Molex part numbers for a 4 pin setup I think should fit together and are available at Farnell at small quantities. Did I find the right parts?
Kind Regards,
Christian
