Multicomp Pro
Multicomp Pro
Documents Multicomp Pro 3d Printer
Join Multicomp Pro to participate - click to join for free!
  • Author Author: kellyhensen
  • Date Created: 19 Feb 2020 9:59 PM Date Created
  • Last Updated Last Updated: 15 Jul 2020 2:02 PM
  • Views 1792 views
See what Matthew thought on his unboxing and initial trial of this Multicomp Pro 3d Printer.
Unsupported video URL format.
Product LinkProduct Link
PRINTER & PRINTING PROPERTIES
Technology
Fused Filament Fabrication (FFF)
Print Head
Single, Direct (non-Bowden)
Build Volume
203 X 232 X 203 mm
Filament diameter
  1. 1.75 mm
Layer resolution
(with 0.35 mm nozzle)
  1. 0.020 - 0.300 mm (20 - 300 µm)
Movement resolution (X and Y AxIs)
  1. 0.00125 mm (1.25 µm) per micro-step
Movement resolution (z AXIS)
  1. 0.001 mm (1 µm) per micro-step
Print head travel speed range
30 - 450 mm/s
Maximum extruder speed
  1. 0.35 mm nozzle: up to 18 mm³/s
Build plate
Borosilicate glass plate with polyimide film
Build plate temperature
20 - 130 °C (enclosed), 20 - 120 °C (not enclosed) at 25 °C ambient conditions
Assisted leveling
Yes, Touch Probe used for automatic and manual adjustments
Printable materials
ABS, HIPS, Nylon, PET-G, PET-T, PLA, polycarbonate, PVA, , TPE, TPU, metal composites, wood composites, carbon fiber composites, and more.
Brass Nozzle Diameters
  1. 0.35 mm standard size
Also available in 0.25, 0.5; 0.75 mm diameter
Stainless Steel Nozzle Diameters
Also available in 0.5 mm diameter
Nozzle Temperature
180 - 300 °C
Nozzle heat up time
< 2 minutes (220 °C)
Build plate heat up time
< 4 minutes (70 °C)
Operating Sound
< 65 dBA
Connectivity
Wi-Fi, LAN
PHYSICAL DIMENSIONS
Dimensions with spool & full range of motion
533 mm (21") x 610 mm (24") x 420 mm (16.5")
Unit weight
12 kg (26.5 lbs)
Shipping weight
19 kg (42 lbs)
Shipping box dimensions
535 mm (21") x 535 mm (21") x 635 mm (25")
POWER
AC Input
100-120 V (4 A)/220 - 240 V (2 A), 47 - 63 Hz
Power requirements /consumption
24 V DC @ 15 A / 360 W maximum
  • multicomp pro 3d printer
    DAB over 6 years ago
    The unit looks like a nice step up from the early days of 3D printers.
  • ankur608
    ankur608 over 6 years ago
    A real Man of Steel!
    The build quality looks more superior than ultimaker, given after some mods like heated enclosure, this could be the next thing in 3DP space.
    -Ankur
