Multicomp Pro
Multicomp Pro
Documents New Waterproof (IP67) Connectors from Multicomp
Join Multicomp Pro to participate - click to join for free!
  • Author Author: GJames
  • Date Created: 27 Jun 2011 2:53 PM Date Created
  • Last Updated Last Updated: 22 Feb 2012 11:10 AM
  • Views 1439 views
2CT3002-W043002CT3002-W043002CT3002-W04300        image
Multicomp, synonymous with great value and quality electronic components, has released a range of IP67 sealed miniature and standard sized connectors and cable assemblies at very competitive prices.
Key Features-
  • Current Rating - 2A, 5A, 10A (Miniature Size) & 5A, 10 A (Standard Size)
  • Corrosion - 48 Hours Salt Spray Contact
  • Durability - 500 cycles minimum
  • Contacts - Gold plated
  • Connector Housing Material - Nylon + GF
  • Cable Material - Black PVC
  • Connector Temperature Range =  -40°C to +100°C
  • Cable Temperature Range =  -20°C to +80°C
Part Numbers
MINIATURE SIZE
DescriptionPart NumberCurrent Rating
PANEL PLUG, PCB , 10 WAY2CT3002-W102002CT3002-W102002A
PANEL PLUG, PCB , 12 WAY2CT3002-W122002CT3002-W122002A
PANEL PLUG, PCB , 4 WAY2CT3002-W043002CT3002-W043005A
PANEL PLUG, PCB , 5 WAY2CT3002-W053005A
PANEL PLUG, PCB , 6 WAY2CT3002-W063005A
PANEL PLUG, PCB , 7 WAY2CT3002-W073005A
PANEL PLUG, PCB , 8 WAY2CT3002-W083005A
PANEL PLUG, PCB , 2 WAY2CT3002-W0240010A
PANEL PLUG, PCB , 3 WAY2CT3002-W0340010A
PANEL PLUG, PCB , 4 WAY2CT3002-W0440010A
DUST CAP, FOR PANEL PLUGS, SCREW-ON2CT3000-W0000W
DUST CAP, FOR PANEL PLUGS, SNAP-IN2CT3000-W0000D
CABLE ASSEMBLY, SOCKET-FREE END, 10WAY, 1M2CT3004-W102002A
CABLE ASSEMBLY, SOCKET-FREE END, 12WAY, 1M2CT3004-W122002A
CABLE ASSEMBLY, SOCKET-FREE END, 4WAY, 1M2CT3004-W043005A
CABLE ASSEMBLY, SOCKET-FREE END, 5WAY, 1M2CT3004-W053005A
CABLE ASSEMBLY, SOCKET-FREE END, 6WAY, 1M2CT3004-W063005A
CABLE ASSEMBLY, SOCKET-FREE END, 7WAY, 1M2CT3004-W073005A
CABLE ASSEMBLY, SOCKET-FREE END, 8WAY, 1M2CT3004-W083005A
CABLE ASSEMBLY, SOCKET-FREE END, 2WAY, 1M2CT3004-W0240010A
CABLE ASSEMBLY, SOCKET-FREE END, 3WAY, 1M2CT3004-W0340010A
CABLE ASSEMBLY, SOCKET-FREE END, 4WAY, 1M2CT3004-W0440010A
CABLE ASSEMBLY, SOCKET-FREE END, R/A, 10WAY, 1M2CT3010-W102002A
CABLE ASSEMBLY, SOCKET-FREE END, R/A, 12WAY, 1M2CT3010-W122002A
CABLE ASSEMBLY, SOCKET-FREE END, R/A, 4WAY, 1M2CT3010-W043005A
CABLE ASSEMBLY, SOCKET-FREE END, R/A, 5WAY, 1M2CT3010-W053005A
CABLE ASSEMBLY, SOCKET-FREE END, R/A, 6WAY, 1M2CT3010-W063005A
CABLE ASSEMBLY, SOCKET-FREE END, R/A, 7WAY, 1M2CT3010-W073005A
CABLE ASSEMBLY, SOCKET-FREE END, R/A, 8WAY, 1M2CT3010-W083005A
CABLE ASSEMBLY, SOCKET-FREE END, R/A, 2WAY, 1M2CT3010-W0240010A
CABLE ASSEMBLY, SOCKET-FREE END, R/A, 3WAY, 1M2CT3010-W0340010A
CABLE ASSEMBLY, SOCKET-FREE END, R/A, 4WAY, 1M2CT3010-W0440010A
CABLE ASSEMBLY, PLUG-FREE END, 10WAY, 1M2CT3024-W102002A
CABLE ASSEMBLY, PLUG-FREE END, 12WAY, 1M2CT3024-W122002A
CABLE ASSEMBLY, PLUG-FREE END, 4WAY, 1M2CT3024-W043005A
CABLE ASSEMBLY, PLUG-FREE END, 5WAY, 1M2CT3024-W053005A
CABLE ASSEMBLY, PLUG-FREE END, 6WAY, 1M2CT3024-W063005A
CABLE ASSEMBLY, PLUG-FREE END, 7WAY, 1M2CT3024-W073005A
CABLE ASSEMBLY, PLUG-FREE END, 8WAY, 1M2CT3024-W083005A
CABLE ASSEMBLY, PLUG-FREE END, 2WAY, 1M2CT3024-W0240010A
CABLE ASSEMBLY, PLUG-FREE END, 3WAY, 1M2CT3024-W0340010A
CABLE ASSEMBLY, PLUG-FREE END, 4WAY, 1M2CT3024-W0440010A
CABLE ASSEMBLY, PLUG-FREE END, R/A, 10WAY, 1M2CT3028-W102002A
CABLE ASSEMBLY, PLUG-FREE END, R/A, 12WAY, 1M2CT3028-W122002A
CABLE ASSEMBLY, PLUG-FREE END, R/A, 4WAY, 1M2CT3028-W043005A
CABLE ASSEMBLY, PLUG-FREE END, R/A, 5WAY, 1M2CT3028-W053005A
CABLE ASSEMBLY, PLUG-FREE END, R/A, 6WAY, 1M2CT3028-W063005A
CABLE ASSEMBLY, PLUG-FREE END, R/A, 7WAY, 1M2CT3028-W073005A
CABLE ASSEMBLY, PLUG-FREE END, R/A, 8WAY, 1M2CT3028-W083005A
CABLE ASSEMBLY, PLUG-FREE END, R/A, 2WAY, 1M2CT3028-W0240010A
CABLE ASSEMBLY, PLUG-FREE END, R/A, 3WAY, 1M2CT3028-W0340010A
CABLE ASSEMBLY, PLUG-FREE END, R/A, 4WAY, 1M2CT3028-W0440010A
Click here to view / buy the products
Europe     Asia
MINIATURE PANEL SOCKETS & PLUG CABLE ASSEMBLIES
PANEL SOCKET, SCREW LOCK, 3 WAY, IP672CT3014-W0340010A
CABLE ASSEMBLY, PLUG-FREE END, SCREW LOCK, 3WAY, 1M2CT3016-W0340110A
SQUARE PANEL SOCKET, BAYONET LOCK, 3 WAY, IP552CT3020-W034A110A
CABLE ASSEMBLY, PLUG-FREE END, BAYONET LOCK, 3WAY, 1M2CT3016-W0340210A
Europe     Asia
STANDARD SIZE
PANEL PLUG, PCB, 7 WAY2CM3002-W073005A
PANEL PLUG, PCB, 8 WAY2CM3002-W083005A
PANEL PLUG, PCB, 9 WAY2CM3002-W093005A
PANEL PLUG, PCB, 3 WAY2CM3002-W0360016A
CABLE ASSEMBLY, SOCKET-FREE END, 7WAY, 1M2CM3004-W073005A
CABLE ASSEMBLY, SOCKET-FREE END, 8WAY, 1M2CM3004-W083005A
CABLE ASSEMBLY, SOCKET-FREE END, 9WAY, 1M2CM3004-W093005A
CABLE ASSEMBLY, SOCKET-FREE END, 3WAY, 1M2CM3004-W0360016A
CABLE ASSEMBLY, PLUG-FREE END, 7WAY, 1M2CM3024-W073005A
CABLE ASSEMBLY, PLUG-FREE END, 8WAY, 1M2CM3024-W083005A
CABLE ASSEMBLY, PLUG-FREE END, 9WAY, 1M2CM3024-W093005A
CABLE ASSEMBLY, PLUG-FREE END, 3WAY, 1M2CM3024-W0360016A
PANEL SOCKET, PCB, 3 WAY2CM3014-W0360016A
CABLE ASSEMBLY, PLUG-FREE END, 3WAY, 1M2CM3016-W0360116A
DUST CAP, FOR PANEL PLUG & SOCKETS, SCREW-ON2CM3000-W0000W
DUST CAP, FOR PANEL PLUG & SOCKETS, SNAP-IN2CM3000-W0000D
Europe     Asia
imageIP67 Circular Connectors-TDS.pdf
  • harsh_environments
  • connector
  • cable_assemblies
  • circular_connector
  • cable_assembly
  • environmentally_sealed_connector
  • ip67
  • multicomp
  • waterproof
  • ip67_connector
